Would this work?If the amp in question is operated at a volume level such that removing the load will not cause the output to rise above the clipping level, then an open circuit on the speaker leads will NOT blow anything. If the amp is operated at a volume level such that shorting the speaker load does not cause the tube current to rise above its peak current rating, or its dissipation rating if the short is long term, then a short will NOT blow anything. This is often the case with a HiFi amp since we tend to listen at a level well below clipping. I routinely switch loads with clip leads on my test amps at a reduced output level (maybe 1/4 the expected maximum power) during amp design. I always test my amps into a short. Never purposefully test a tube amp into an open unless you KNOW what will happen, AND are prepared for the worse. An amp with feedback, especially global feedback, may misbehave into a short or open attempting to correct the situation, causing clipping or excessive current.
This is NOT the case with a guitar amp. A well designed guitar amp should be capable of operating into extreme clipping continuously without damage.
Let's assume that Mr. Metalhead uses a pedal board with a million DB of gain and cranks everything to 11 and while performing a 15 minute trainwreck solo. The output tubes operate as switches, alternately switching each plate lead to ground at a 250 Hz or so rate. Assuming no saturation in the OPT (not a guarantee, especially with a Fender) the tubes will not see much stress since there is little average dissipation. One plate lead will be pulled toward ground by a saturated tube reaching 30 to 70 volts depending on the tube and driver circuit. The current reaches a maximum as the plate voltage goes near zero. This current is limited by the B+ and the instantaneous load IMPEDANCE reflected to the tube by the speaker and the OPT. The other plate is essentially OPEN CIRCUIT because the tube is cutoff. The half primary with the cutoff tube is essentially an unloaded secondary, and it's plate terminal will usually rise to about twice the B+ voltage if the secondary is operated into a perfect resistive load.
A speaker, even a mild mannered HiFi speaker is NOT a resistive load. A guitar speaker, or combination of speakers, usually has a resonance WITHIN the frequency range that a guitar operates. It's impedance can go to 30 ohms or more around resonance. (70 to 150 Hz). It can also generate considerable counter EMF when fed enough power to make the cone dance. Bass guitar speakers around resonance are worse case. A speaker also has an inductive and a capacitive component, it is not resistive.
It is not unusual to see peak plate voltages exceed THREE TIMES the B+ under normal operating conditions, and more if the (bass) player likes to slap the strings around.
The definition of inductance is the property of an electrical element that opposes a CHANGE in current flow. Any coil of wire has inductance. A lot of wire wrapped around an iron core has a lot of inductance, and so does any winding on an OPT. An OPT has at least two windings that are COUPLED magnetically. A change in CURRENT through any winding causes a change in current flow in all other windings. As long as there is a path for current to flow in at least one other winding everything is OK, the OPT will transfer the changing current flow in a primary winding to a secondary winding which becomes a changing current through the load (speaker).
If there is no load present, the conducting tube will switch one plate lead to ground causing a current to flow through the OPT half primary. This current will build up quickly to a very high level limited only by the DC resistance of the primary and the internal resistance of the tube, since there is no AC load to absorb the changing current. The property of inductance will attempt to keep this current flowing as the circuit reaches it's steady state current level, FORCING an overcurrent situation and causing the plate voltage on the conducting tube to swing NEGATIVE. Now BOTH TUBES become open circuits and there is NO path for current to flow! AT this point there is a large magnetic field in the OPT, and it MUST go somewhere. The previously conducting tube will see it's plate voltage go "flyback" to an extremely high negative voltage while the opposing plate will go to an extreme positive voltage. In an ideal (lossless) transformer the voltage will theoretically go to infinity! In reality there will be an arc somewhere. This is how the ignition coil in your car works.
I have seen voltages over 5KV on an amp with a B+ of 420 volts. I have set an OPT on FIRE by testing a cranked amp when my load resistor blew open. I since bought some 8 ohm 500 watt resistors.
Catching fire?
Amplifiers have many different failure modes.
It is a good idea to not have fires in any amp, but to protect against some of the causes:
All my tube amps have a fast blow fuse wired in series with a slow blow fuse (on the primary circuit of the power transformer).
The fast blow amp rating is larger than the slow blow amp rating.
The fast blow is the smallest rating that does not blow during power-up inrush current.
The current can vary depending on exactly when in the power line cycle you close the mechanical on switch (with a dead cold amp).
The slow blow is the smallest rating that does not blow during warmed-up continuous current, and loudest music played.
Of course, the amp needs to be designed so that no component is pushed beyond its rating during any of the above.
This thread started as a tube output protection question.
But since it has now included the amp catching fire, I thought a little
protection of the amp from a power transformer fire might be in order
(and the fusing method I listed may also protect against some output tubes or output transformers that short, or even catch fire).
What secondary are you wanting to fuse?
B+ 1, Center tap, B+ 2, Filament?
Output transformer Secondary?
I assumed that the slow blow fuse is there to act when the power tubes draw excessive current. I thought to ask if that would work on the secondary of one power transformer supplying all stages.
Power transformer primaries short, power transformers secondaries short, output tubes short, electrolytics short, fixed bias supplies go dead (or the adjustment pot wiper opens) output transformers short (I once had an output transformer that had a short from primary to the laminations and end bells . . . to ground).
Of course you could fuse the secondary. But the problems would be multiple.
1. You could fuse the two B+ taps
2. You could fuse the B+ center tap
Caution:
Both of these would require a very high voltage fuse, not the usual 250V fuse.
And high voltage fuses generally do not come in as many current values as the 250V fuses. And it may be harder to find the type you want (fast blow, slow blow).
3. If the power transformer shorted (any of the transformer windings) fusing the secondary or secondaries would not protect the transformer.
That is why I do it the way I do, I fuse the primary.
Caution:
Overcurrent protection does little to protect devices if the root cause is overvoltage. They only prevent the fire after the fact - the output transformer is still ruined if you burn thru the insulation. Even if the damage is localized and doesn't bring the fire department or set off the smoke alarm.
And I'll bet good money that the flyback spikes produced by an under-loaded OPT sound better (as in more desirable harmonic structure) compared to just clipping them off with proper free-wheeling diodes. That kind of distortion in general usually sounds "buzzy" or "transistor-like".
Let's see if this link works
I always try to protect the output transformer, not the tubes.
I have seen dramatic OT failure (Marantz 8b), with primary to chassis short.
Took down the choke and damaged the PT, primary fuse went off, too late.
A fuse on the B+ would have saved the choke and the PT.
I have seen a bad driver tube on a McIntosh MC240 with a beautiful purple tube arc. The internal fuse on the HV supply blew. No damage to anything.
I have seen 2 runaway EL84s with loss of bias. Smoked the cathode resistor, B+ fuse did not blew as it was sized to protect the 2 channels: mistake. No damage as the user was quick to shut off the amp.
Since then I always add a fuse either on the HV center tap if any, or before the voltage doubler or on the B+ supply rail before the rectifiers. Here I use a slow blow 1 or 2 amp.
It does help but not if you only have 1 runaway tube melting away the OT primary winding it is serving, unfortunately.
For that reason, I also like the cathode fuses option, to protect each side of the primary OT by choosing the right fuse.
I found that 3x the idle current fast blow will hold. Less and you might blow the fuse for no real reason at full blast volume. I also usually add serial to the fuse a 1R sensing resistor for bias adjustment and balancing.
I am aware of the non linearity of fuse with temperature, and it's resistance is far from zero ohm, but I can not honestly say it does affect the sound.
There is no silver bullet. Even the new MC275 with active monitoring sometimes has failure.
It's all about balancing the odd and know what you are protecting and for what condition, without affecting the sound.
Did I share already what I do?
I use a pair of high voltage SS damper diodes, counter-parallel to tubes in PP amp. It protects output transformers.
What methods and techniques are there for protecting tubes and the output transformers in the case of a short or open circuit? I am building a tube amplifier using kt88's in a push-pull configuration. I would like the amplifier to have protection incase the amplifier is ran without a load or if a load shorts.
Thanks!
A simple resistor across the output will damp the output transformer if there is no load. It doesn't have to be 8 ohms even a 100 ohms will do.
How about an air bag in case the amp gets dropped ?
The requirement for a fuse with a voltage rating higher than 250VAC is not the advise provided by fuse manufacturers for secondary side protection.Of course you could fuse the secondary. But the problems would be multiple.
Caution:
A 250VAC rating applies to coping adequately with a high prospective fault current that can occur on the primary side. Fuse manufacturers advise that higher secondary winding voltages can be managed by a 250VAC fuse as the prospective fault current is not as high due to winding resistances and impedances. I'd suggest that unless your amp is seriously high B+, then standard 250VAC fusing is fine.
If you're not limited to only buying typical north American UL248-14 style fuses, then the IEC 60127-2 rated fuses provide much better definition of performance, which can be better matched to the particular amp you have if you are keen to apply an appropriately sized and style of fuse.
I had hoped that all who read my post # 86 would read All of the post.
I did not recommend doing secondary fusing, but said you Could do that, and leaving the research up to an educated person who was willing to do the research on what fuses might possibly work safely. And then I mentioned there were other safety concerns (such as a power transformer short).
Suppose you fuse the secondary center tap, and the (sometimes twisted) wiring to the rectifier plates shorts, or the rectifier socket shorts, or the rectifier shorts, the center tap fuse will protect nothing.
And fusing all the secondary leads will not protect all contingencies.
That is why I closed the post with the one method I always use:
Fuse the primary with a fast blow and slow blow in series.
I have 120VAC power, but always use 250V fuses.
I use all the components in the amplifier conservatively versus their maximum ratings.
power transformers, chokes, output transformers, capacitors, resistors, tubes, etc.
I have worked with UL on safety issues (and there are many that you might not suspect).
I have even made recommendations to UL on proper measurement setups for them to get accurate and repeatable test results.
My power source is Hot, Neutral, and Ground.
The amplifier power wiring is IEC socket Hot to fast blow fuse, slow blow fuse, on-off switch, transformer primary lead 1, transformer primary lead 2, IEC socket Neutral.
IEC ground to amp chassis (ground).
Simple, but the shortest path is to the first fuse. (no pun intended)
No probs - I was just clarifying the voltage rating of a fuse if it were to be used on the secondary side, as that is a common enough practise by many and the issue often arises as to how to fuse a winding that has a higher VAC than the fuse VAC rating.
Fusing beyond just the primary can certainly provide better discrimination for faults within the circuitry of amplifiers, depending on where the fault is. I would certainly recommend diyers to carefully consider if secondary side fusing can be advantageous, over and above appropriate primary side fusing. The linked article goes some way to helping diyers go though the technical hoops needed to make a good choice of fuse size and type.
https://www.dalmura.com.au/static/Valve%20amp%20fusing.pdf
I'm lucky. I use 250VA power transformers (VPT18-13800 if anyone is interested) as OPTs on my main amp. Since the wire is that much thicker it has survived an arc over or two through a bad tube. I only fuse the primary of the PT, and it's only there to prevent a fire.
I have fused output tube plates, and it can be done OK.
But then you have to consider the implications:
You should not use a common self bias resistor (not when you fuse plates).
(and for good matching over time, should use separate self bias anyway).
With separate self bias, and one plate fused open, and the consequential B+ rise, you have to watch where the other tube will self bias, versus its bypass capacitor voltage rating.
You have to consider once the output tube plate fuse blows, or multi plates fuses blows, will the B+ rise to a high value that will be beyond the B+ electrolytics voltage ratings, not just the first one, but all the way down the CLC R C R C B+ chain.
You can fuse the output transformer primary center tap (but again, you have to watch the B+ voltage rise, and electrolytic voltage ratings).
You can fuse the output tubes cathodes, but then you have to watch the filament to cathode voltage ratings; and depending where you connect the fuse, you have to watch the self bias capacitor voltage ratings, etc.
I remember a Lead Acid Gel Cell in a metal pack, that connected via a wire to a voltage invertor in another metal pack. It was CSA approved.
But there was no fuse leading from the Gel Cell to its output connector. The invertor had a shorted RF bypass capacitor at its input connector. When the two were connected, the wire connecting the two packs smoked.
The product offering was quickly modified to include a fuse in the gel cell pack.
We all make mistakes of one kind or another.
etc.
etc.
A spark gap is the least intrusive and simplest OPT protection against kV spikes.
In the old days a 100W Pa amplifier would have such a simple device soldered directly between the output transformer plate to plate connections.
Now days those spark gaps are unobtainium and I make them myself if needed.
Those without the necessay know-how or not so into DIY should use a reasonable selected MOV instead.
- Tubes / Valves
- Tube output protection
