Tube-I-zator Professional PCB
Hi Oliver,
I already received my (the two pins) switch which is not useable for the board. I'll just put a jumper on the board instead of switch. Can you please show the blow up on the switch area showing which via (pad) to connect instead of switch if I'll use tube model 12t7/ecc81. Thanks.
