Ive just bought one of these on ebay which uses a pair of 6N3-Js.
Works well but gain is a little low. Traced out circuit shown below.
I assume that the gain is defined by 10K feedback resistor and 2k2 cathode resistor. Decreasing feedback should increase overall gain.
Circuit specified at rectified 150v for B+ supply. Will however give useful output if B+ is reduced to 50v
Just a suggestion.
Tony.
Just a suggestion.
Tony.
6N3=5670
6N3=6N3P=2C51=5670
Cheap 5670 currently on ebay and also Soviet 6N3P-EV can routinely be found for under $2/piece. Both sound much better than Chinese 6N3
If it is the same 6N3 that you find in Russia (with nominator 6N3P), then an ECC85 or 6AQ8 is equivalent.
6N3=6N3P=2C51=5670
my very first diy amp
a few weeks ago I build (not yet finished):
6N3P preamp, LM3886 amp modules, ALPS pots, JantzenAudio terminals for speakers, JantzenAudio Silver cable. Sounds very good. Still working on front panel.
Next step - planning to change Wima capacitors with PIO on preamp
6N3=6N3P=2C51=5670
Hello
I also have a few 6N3P-DR, easy to find on ebay, but obviously more expensive.
About Chinese buffers 6N3, improvement is indescribable. Are 10,000 tubes use goldgrid (the meaning - DR tubes, if I am wrong, with security in NOS tubes)
but without a doubt the -EB, as you say, already provides as much improvement at low price.
All the best
Fernan
Hi Soundbrigade
I the Germany speec, the ECC85 always try the direct replacement 6N1P,
I believe that no China or Russian 6N3, reaches values max. of the ECC85 and/or 6N1P, please correct me, If I'm wrong.
As a curiosity, in FM detection, replacing the ECC85 by 6N1P, say that the reception is better, with better sensitivity.
Greetings and
All for the best sound,
thanks to the Forum and your whole respectable participation
Fernan
I am new to tube audio. I wanted to start with just a little pre-amp. Is this the refined version of that amp? the circuit looks similair. It does carry a slightly beefier transformer though.Ive just bought one of these on ebay which uses a pair of 6N3-Js.
Just a suggestion.
Tony.
I just saw this
QINPU Q-2 mini HI-FI VACUUM TUBE INTEGRATED AMPLIFIER 100% BRAND - $67.39USD : Enjoy music, enjoy hifi audio!, we sell Music Angel,qinpu,yaqin,MeiXing MingDa,Bewitch,Bada Amplifiers, CD player,power amp, preamp
Looked up the tube and got a half wave rectifier which doesn't make sense. I suspect it is a mini dual triode running a chip amp with low wattage. Pretty cool for $70.
I was looking for the tube and found the amp, and this thread. Google really is changing things.
Thatch
Thatch
Do not think there confuxión copy with small double triodes China.
I tried 6n1, 6n3, 6n6, .... (Js, Chinese military star?)
I can not find much in common with Russian NOS. (to sound less)
As a curiosity, in my bijou headamp, 6n6 (J) Chinese doubles the current in the output buffer!?
Exactly! the price is low.
re-tubing, re-caps (possibly any modification more)
Enter the world of valves at low price Chinese components.
Good starting point to experiment and improve!
All the best
6n1p, 6n11, 6n23p, 6922, 6dj8, ecc88, 6aq8, ecc85 pinoutI the Germany speec, the ECC85 always try the direct replacement 6N1P. I believe that no China or Russian 6N3, reaches values max. of the ECC85 and/or 6N1P, please correct me, If I'm wrong. As a curiosity, in FM detection, replacing the ECC85 by 6N1P, say that the reception is better, with better sensitivity.
But that is different than
6n3p, 6n3-j, 2c51, a2690, 5670, 396a, 6385, ecc42 pinout
However. . .
For connecting different tubes, such as those above, there exists "socket adapter" that comes pre-wired, and "socket saver" and both look like this.
Oddly enough, the commercial adapter models that I could find were made for changing 6922 socket to use 6n3p tube, rather than the other way around. These don't seem to include any adaptation of support circuit such as current, resistors, etc. . . so that is DIY, and therefore I can't imagine a use for the adapter.
so, you run both the chip amp and the 6n3 buffer with the same transformer? what are the specs for such transformer? and where to get one?
Please let me know
- Tubes / Valves
- Tube 6N3 use pre for ChipAmp
