Tube 2E22 in triode mode
Here are some measurements of 2E22 in triode mode
G2 G3 connected to Anode.
I made spice 2 models, same but one for DHT, other standard.
Maybe it could help to establish needed and optimal settings?
these settings could be use for fain stage input with 4Vp-p. (Not for Amplifier...)
Code:
****  Composite DHT *****************************************
* Created on 01/16/2025 17:49 using paint_kit.jar 3.1
* www.dmitrynizh.com/tubeparams_image.htm
* Plate Curves image file:
* Data source link: 2E22 triode mode measurements DIY audio site
* Vf=6.3V If=1.5A Pa=30W PG2=10W
* Capacitances in triode mode are estimated
* A+G2+G3
.SUBCKT 2E22_DHT 1 2 3 4 ; P G K1 K2
+ PARAMS: CCG=13.7P  CGP=9.7P CCP=8.7P RFIL=4.2
+ MU=8.874 KG1=1395 KP=64 KVB=300 VCT=-2.85 EX=1.412 RGI=2000
* Vp_MAX=600 Ip_MAX=140 Vg_step=5 Vg_start=5 Vg_count=14
* Rp=4200 Vg_ac=0.25 P_max=40 Vg_qui=-11 Vp_qui=247
* X_MIN=51 Y_MIN=119 X_SIZE=922 Y_SIZE=443 FSZ_X=1763 FSZ_Y=690 XYGrid=true
* showLoadLine=y showIp=y isDHT=y isPP=n isAsymPP=n showDissipLimit=y
* showIg1=n gridLevel2=n isInputSnapped=n
* XYProjections=y harmonicPlot=y dissipPlot=y
RFIL_LEFT    3  31 {RFIL/4}
RFIL_RIGHT   4  41 {RFIL/4}
RFIL_MIDDLE1 31 34 {RFIL/4}
RFIL_MIDDLE2 34 41 {RFIL/4}
E11 32 0  VALUE={V(1,31)/KP*LOG(1+EXP(KP*(1/MU+V(2,31)/SQRT(KVB+V(1,31)*V(1,31)))))}
E12 42 0  VALUE={V(1,41)/KP*LOG(1+EXP(KP*(1/MU+V(2,41)/SQRT(KVB+V(1,41)*V(1,41)))))}
RE11 32 0 1G
RE12 42 0 1G
G11 1 31 VALUE={(PWR(V(32),EX)+PWRS(V(32),EX))/(2*KG1)}
G12 1 41 VALUE={(PWR(V(42),EX)+PWRS(V(42),EX))/(2*KG1)}
RCP1 1 34 1G
C1 2 34 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 34 {CCP} ; CATHODE-PLATE
D3 5 3 DX ; FOR GRID CURRENT
D4 6 4 DX ; FOR GRID CURRENT
RG1 2 5 {2*RGI} ; FOR GRID CURRENT
RG2 2 6 {2*RGI} ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS 2E22_DHT
* Created on 01/16/2025 17:50 using paint_kit.jar 3.1
* A+G2+G3
.SUBCKT 2E22_triode 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=13.7P  CGP=9.7P CCP=8.7P RGI=2000
* showLoadLine=y showIp=y isDHT=n isPP=n isAsymPP=n showDissipLimit=y
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G  ; TO AVOID FLOATING NODES
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G   ; TO AVOID FLOATING NODES
C1 2 3 {CCG} ; CATHODE-GRID
C3 1 3 {CCP} ; CATHODE-PLATE
D3 5 3 DX ; POSITIVE GRID CURRENT
R1 2 5 {RGI} ; POSITIVE GRID CURRENT
.ENDS 2E22_triode
This tube is a dht pentode 😀...why are you making it a triode? Enjoy the pentode mode. I've made it a few times and it's great.
Hooman, thanks for the encouragement 😀. I'm building it on a Tubelab board, switchable Pentade /Triode.
Recently built a GU50 (SSE), with G2 & G3 strapped to the anode and it sounded WOW (Softone RW--20 OPT). So, I thought lets give the 307a & 2e22 a shot.
Code:
* A+G2+G3
RE11 32 0 1G
RE12 42 0 1G
RCP1 1 34 1G
.ENDS 2E22_DHT
* A+G2+G3
.ENDS 2E22_triode
Thank you Zoran. This will be very helpful 🙂👍
  • Thank You
Reactions: Zoran
It's very interesting to hear good sound from cheap tubes. This is an art. Regarding the maximum g 2 voltage... it is listed in the manufacturer's data as 250 volts. Does anyone know about this?
