Two important points. Don't forget that, in a CFB amp, changing the serial feedback resistance value will change the slew rate. Changing the emitter resistance value will change the current in the input transistors.
So if you want to add some gain, the best is to replace the serial resistances by an attenuator, keeping the impedance seen by the input transistor near the same.
By example, if your original serial resistance is 1K and the emitter 50 Ohms, from the output, do 1Kserial +1k to gound and 500 Ohm to the 50Ohm.
From 100R to 50R when talking the ground return Fb ones for +6dB?
Yes, these ones.
Sonny supplied both values with the kit.
Hi Esperado.
With a reasonable bandwidth, reducing the emitter resistor will not cause any high currents in the audio range. But i have and will recommend any one to have a lowpass input filter.
For two reasons:
- Reduce emi from the line signal - cellphones in particular
- Reduce slewrate allowed even if the amp is capable of more. It stresses the transistor and zobel network a lot with "extreme" slewrates.
By leaving the Rf value and reducing the emitter resistor you will raise the loop gain... So by adding +6dB system gain, this way the loopgain stays the same.
The 200kHZ square waves pics are with no bypasses at all. Not on rails, not on feedback. Perfectly stable. I don't know if the bypasses speed it up more, but with just the FC lytics, I found the -3dB point at circa 2.5MHZ (6 vertical divisions reduced to 4 rough check point).
I will maybe change the DOC to say that they should start out without the bypass caps in the feedback network.
They can always add them later.
I too, of course. But keeping the ratio signal speed/amp speed as little as possible is the target. If no stability issue, i would reduce the serial feedback resistance instead. Keeping a low-pass filter at 200Khz before the input.HWith a reasonable bandwidth, reducing the emitter resistor will not cause any high currents in the audio range. But i have and will recommend any one to have a lowpass input filter.
May-be i need to precise my point. Decreasing the emitter resistance of the first stage will increase the gain of the input stage, as its collector one will stay the same. If the amp has been carefully designed for each stage produce the same distortion in open loop, you will increase-it. And the quiescent current will be increased as well. Right ?
That's why i recommended to not touch this resistance.
On the contrary, reducing the serial feed-back resistance will stay the input stage unchanged, and reduce the influence of parasitic influence near the emitter of the input transistor because impedance will be reduced.
Agree. I tried that too. But then millercaps should be larger.
That was what real life tests showed.
Secondly its thermal stability gets worse when Rf was reduced. Not as bad as is the SSA design. 😉
2.3mV/K across 1K instead of 100R in the SSA. That is a 10 factor.
No the quiescent current will not increase, It is controlled by the current source and Rf. The emitter resistor is AC coupled to GND.May-be i need to precise my point. Decreasing the emitter resistance of the first stage will increase the gain of the input stage, as its collector one will stay the same. If the amp has been carefully designed for each stage produce the same distortion in open loop, you will increase-it. And the quiescent current will be increased as well. Right ?
That is correct but you will raise the bandwidth. And my test showed that this is NOGO . 33pF and Rf=1K is the limit. Reducing Rf means larger Millercaps ....That's why i recommended to not touch this resistance.
Can't you add a // cap with the feedback resistance to keep the closed loop bandwitch the same ??That is correct but you will raise the bandwidth. And my test showed that this is NOGO . 33pF and Rf=1K is the limit. Reducing Rf means larger Millercaps ....
For the quiescent, my amp use a ccs referenced to rail, so we are not in the same situation, you are right.
If it is okay, you can show me the circuit. Just so that i can follow you.
No as with rising frequence the cap will start act as a smaller Rf. And it currentfeedback this oscillation will start
Where is your schematic, for i can be more accurate ?
I know this amp is very sensible and each pole change can have a lot of consequences...
Well, i understand better your choice, now. I would try a 2K for R11 - R12 and a little paralleled cap with it for stability and no overshoot on square waves, if possible.
The thing i worry, looking at your schematic is the one octave upper high pass filter frequency if we decrease the R13 -R14 from 100 to 50, right ?
You have better experience on it, anyway... I suppose you have tried near everything ?
You are right. I remembered wrong. It is 47pF millercaps. Withe 33pF we starts to have small signs of oscillation driving capacitive loads.
There is always something new to try. 😀
My problem is that my time flyes away. Right now i am doing a stepup LED driver for a new display for a customer as the OLD display was EOL!!! It is 23:37 .. stupid stupid .. When you can make audio instead....
So to put it in a nutshell, is George's move to go 50 Ohm +6dB worsening the stability or THD spec or does something else negative? He loses 6dB feedback and some damping factor is one thing I would suppose, but he drives a 20 Ohm+ load.
No it is not. It works very well. My protoamp has run for months with this configuration.
No need to worry.
By using 50R you do not lose feedback. Distortion is the same. Damping factor is the same.
No need to worry.
No need to worry.
You have to focus on the RF (R11 and R12) combined with the millercaps (C12 and C13).
They set the bandwidth. Do not place a cap across R11 and R12 . It will oscillate right away with a capacitive load.
- TSSA - The Simplest Symmetrical Amplifier
