It won't be a CLD if you change the materials of the layering, and i wouldn't use any of the commonly used CLD material (it wants to be inside the box wall). A layering of different materials (even just different thicknesses of the same material) could be beneficial. Multiply, chipboard, MDF, aluminum plate, even glass might be useful.
dave
dave
More pics of the second cabinet:
Number 2 standing on her feet, closely watched by number 1 running in the drivers
Soldering connections to the cables so that drivers can easily be taken out without soldering
Sealing the x-over cables into the mid volume
Inside view of the closed mid volume
Inside view of the woofer area with the binding post and some heat shrink to polarize
pimped cables 😛
Bitumen mats again on mid cover
Gluing the bottom cover and feet
pimped cables 😛
I have just put a CNC machine on my wishlist for cristmas, is i to late? 🙂.
Very cool projekt an very well build, lokking forward to follow the projekt.
Busk
Busk
Well Busk, you know how that works with Santa Claus.... have you been a good boy this year ? 😀
Thanks for you comments!
And "Glædelig jul!"
And "Glædelig jul!"
I wish we at "Klang + Ton" were able to put so much time and effort into a pair of speaker cabinets.
Very inspiring, thank you for that.
And "Glædelig jul!"
Joyeux Noel et Bonne Année!
Thanks a lot for the compliments. I highly appreciate given the quality of your projects.
Merry X-mas to all!
A couple of pics more...
Wish you all a merry x-mas and see you back soon!
Happy New Year 2010 !!
Hi All,
just back from a couple of days off.
I wish you all a Happy New Year 2010!
I will keep you updated soon on the progress.
WaveFlex
Hi All,
WaveFlex
Getting to the end... last couple of pics
All of it assembled, just missing the top cover as you can seee)
Tweet-Med front baffle in place, preparing to drill the chassis-fixing holes
Hello, WaveFlex!
That is a very nice build you have going on there! I'm a big fan of the look of the PMS, and this is already a very beautiful build. I'm looking forward to the finished pictures, and seeing how they are finished!
Are you able to use the CNC machine through your work? I do wish I had access to such a machine.
Hello, WaveFlex!
Thanks a lot for your comment klankyman. Actually the are in the progress of getting finished... be patient 😎
Yes indeed for the CNC, wouldn"t mind having one for myself in the basement though..😀
Assembled cabinet
Just before closing time... should dig out that album btw...
Hello WaveFlex,
This is a great project. Could you please tell me what did you use for making the drawings for each layer? Which CAD program?
Thank you!
Thank you!
Hello WaveFlex,
Thank you!
Thanks for your comments SunRa!
Actually as mentionned earlier in this thread I use 2-D design software, any open source clone of Illustrator to name it or your preferred software should do.
The 3rd Dimension is somewhere in my brain...
Some pics in bulk
On special request from franck 😉
- Troels' PMS (multilayer assembly) build thread
