My father-in-law wants to bring me from Russia some tubes. What would you recommend? Any good power triode from Russia ?
Thanks,
Davide
Thanks,
Davide
Thanks,
Davide
GM70 copper plate!
GM70 copper plate!
I'll second this one! 😛 It sounds very, very good and is sufficiently expensive outside of Russia to justify the trouble.
Many surplus Russian tubes are available worldwide quite cheaply so it pays to be choosy and grab types that are less common and more expensive in Japan. Take a look at what tubes are available on eBay and what their typical cost with shipping would be. Look for the rarer and more expensive types, and not necessarily just triodes. 4P1L would certainly also make this list IMHO..
6S41S / 6C41C / power tiode
http://www.tkhifi.com/datablade/6c41c.pdf
I would like to recommend you and those double triodes.
- 6N30P ( 6Н30П )
- 6N23P-EV ( 6Н23П-ЕВ ) similar to 6922
- 6N6P ( 6Н6П ) similar to 5687
and last but not least 4P1L ( 4П1Л ) and 6S4S ( 6С4С )
With greetings
- 6N30P ( 6Н30П )
With greetings
The legendary and elusive -
12C42C
Summit like a 6C33C but double the ratings! Its talked about but Never ever seen, but apparently does exist.....
Most other stuff like GM70 you can get readily anywhere....🙄
12C42C
Priamo w desiatku!! /Target's center!!/You forgot about 6S19P (6С19П)?
Definitely:
-6c4c
Optionally (not power triodes)
-6h8h, 6h9c, 6h1p, 6h2p
-5u3c, 5u4c
-6pi14c
-6c4c
-5u3c, 5u4c
-6pi14c
Also, now lots of miniature military tubes are available: 6N16B (tiny version of 6N1P), 6N17B (tiny version of 6N2P), and so on... Nice pentodes of similar pen-size: 6J32B, 6J5B, 6J9B. Even tiny power pentodes like 6P30B.
Metal-film resistors are available, like used by military MLT, C2-23, C2-22, or even non-inductive wirewound PTMN.
Capacitors, as well... Silver mica; hermetical silver mica, polyester, paper in oil... Except electrolytics: they are not good. Except, may be, used by military K50-29, but they are still expensive.
Edit: Ohh, I almost forgot about the best tube for mic preamps and MC phono inputs I ever saw: 6S17K-V.
Yet another vote for 6S4S ( 6С4С ). This is a good tube.
6C4C = 6S4S = 6B4G tube. Svetlana factory - Vacuum radio tubes, capacitors, socket for tubes, nixie, ferrites from military Russia. Datasheets tubes and help. Worldwide shipping
It's an equivalent of 6B4G, different base and filament voltage to a 2a3 but otherwise similar. It could be used as an output tube - particularly in push-pull. It could be used as a driver for a 300B SET through a nice interstage transformer like a Hammond 126C. It could be used as a preamp tube again through a nice output transformer like a Hammond 126C. Very versatile and good value. Heck, you could make a three stage amp with just these tubes, and it would sound good!! Get a dozen!!
Andy
Andy
The datasheet says it's for use as a voltage regulator, is this how you would use it Wavebourn? Gain looks low but the curves look quite linear...You forgot about 6S19P (6С19П)?
Gm70 triode definitely!!! Great directly heated triode constructed for AF amplifiers and AM modulators.
Metal base 6N8S made in MELZ, Moskovski Elektrolampovni Zavod
Metal base 6N9S made in MELZ, Moskovski Elektrolampovni Zavod
6N30P
6S33S-V 6C33C-B Audio triode
And if you need cheap sweep tubes 6P41S and 6P45S ...
6N30P
6S33S is for voltage regulators as well. I am going to design some 2.5W SE amp using 6S19P tubes.
Cheap alternative to a 45 perhaps?I am going to design some 2.5W SE amp using 6S19P tubes.
- Tubes / Valves
- Triodes from Russia
