Would you be so kind as to add the 6P41S?
Ayumi Spice models are in post 41 : 6P41S spice models
Datasheets with curves in post 42: 6P41S datasheet w curves
Thank you.
Thank you.
@gsmok, would you consider to open source your software, since both your websites are abandoned? Thanks.
I found a thread in Poland talking about the simulator. gsmok's last post there is November 2023. I ran it through google translate:
https://forum--trioda-pl.translate...._sl=pl&_x_tr_tl=en&_x_tr_hl=en&_x_tr_pto=wapp
Sorry I haven't replied for a long time, but I haven't been checking my favorite Forum. The aforementioned websites (TRIODA.COM) are indeed not active now. I hope it's only temporary. I have forwarded their content to the newly established Trioda Association in Poland. They will be reactivated. The aforementioned online simulator will also be active again. There are probably no objections to the fact that if any of you colleagues have such an opportunity, I can pass on (with the Association's consent) the program code to be made available again to interested parties. In the meantime, I have made improvements to the program that allows generating Spice models based on measured tube parameters, which can be used in programs such as LTSpice. I am still checking this script. Its test version was once available on the www.trioda.com service. I will try to add it to the new version of the service run by the aforementioned Association.
Hi gsmok,
Thank you! Your simulator proved very useful when I teach about vacuum tube operation at the California Historical Radio Society museum (californiahistoricalradio.com). I'm very happy it will be active again! We would be happy to help keep it alive in some way.
Regards, Kent
Regards, Kent
Hello
Looking forward to finding your calculator for my favorite tubes: 813,833a,c3g,10y,e188cc.
Kind regards
Denis
Kind regards
Denis
Hello
At the moment the simulator version is available at: Tube Loadline Simulator
I am not sure if this is the most up-to-date version. I will try to check it. In the near future I will also try to work on updating the program.
gsmok
gsmok
On some forums (Reddid) there are comments about the poor accuracy of the program's calculations of some parameters 🙁. The accuracy at the "retro" level concerns primarily nonlinear distortions. It results from the fact that they are DELIBERATELY determined in the way it was done in the era of electron tubes, i.e. using geometric methods directly based on characteristics. I implemented in the script exactly the method of calculating individual harmonics as it was done using a ruler and a setsquare in the old days. Hence, on some forums I was accused of the fact that the accuracy of the simulator's calculations is insufficient (and this is the case in the era of computers - I could finally implement an exact algorithm for calculating distortions and other parameters). But I am a fan not only of electron tubes, tube circuits, but also of the methods of designing electronic circuits used in the era of electron tubes, for which I apologize in advance to those disappointed by the program's imperfections.
Hi gsmok, nothing is perfect. For the example, there are so many different types of 300B tubes in the market. Their characteristic varies from one to the other. There's no way keeping update for every one of them.
We all appreciate in your efforts in working on the program so that we could have a tool finding the best working condition of the tubes.
Johnny
Johnny
I have prepared a new page dedicated to electron tubes and here is the section where I have placed the simulator program. I hope that I will not change its place on the Internet any more. I apologize for the confusion.
- Tubes / Valves
- Triode/Pentode Loadline Calculator
