Before the Tri-Path website went down, I was looking into possibly building a class-D amp. I saw somewhere a single IC, that did all the work (feedback, PWM, etc) and you just needed small components (resistors, caps, inductors, etc) to add to it and then have this IC run into some FETs and you were basically done (well you know what I mean). The board really only had a handfull of parts on it, and seemed quite simple to make. Where can I find this again? I would like to start off small (10-50watts) and soon make a 500watt+ sub woofer amp. Thanks
