Transformers proximity
Hi all,
I'm currently building an audio power amp. I'm wondering about the minimal distance I should consider between two transformers.
I'm going to use two R-core transfomers, one is 2x30V/300VA, the other is 2x12V/30VA. Should I expect problems if the two are too close to each other? Is this a non-issue?
Thanks!
