Transformer from Sony A/V Receiver - what's up with these windings?
A friend gave me a transformer from a Sony A/V receiver. He didn't know the Sony model, I think it was 7 channels, or maybe 7.1, possibly 100 Watts per channel. I figure if Sony was claiming 7 channels of 100 Watts, it might be a good start for a 2 channel 100 Watt amplifier. Output devices are MP1620 / MN2488.
The secondary high current winding has 5 wires, with voltage as follows, measured with 120 VAC on primary, no load on secondary:
Orange - 44
Yellow - 27.4
Black - 0
Blue - 27.4
Red - 44
So, we have the makings of a +/- 62 VDC or +/- 38 VDC supply. According to my math, that would be about 240 Watts or 90 Watts into 8 ohms.
Anybody know how this thing was used? Guesses also welcomed.
Hmmm. +/- 38 VDC is a bit high for a preamp, and I have no idea what a flatamp is (neither does Google 🙂 ). And this is the high current winding - there is a separate low current winding measuring 14-0-14 that is almost certainly for the low-level stuff.
Thanks.
Instead of guessing get a service manual! Flat amp term used to decribe a driver section of a preamp( yamaha's term anyway) as in flat response no coloration of source signal. My yamaha C-4 PREAMP runs a +/- 45vdc so 38vdc is not out of the question.Have you tried a Sony techline.....
A number of AVR's including Sony have a switch on the back labeled 4 0hm vs. 8 ohm. The purpose is to get the user to use lower rail voltages with 4 ohm speakers. This indicates to me either that there are heat dissipation issues with a 4 ohm load or SOAR issues or both.
Such a switch would change which set of windings connect to the rails. I can't say this is the case in the example at hand, but it is a possibility.
