This seems to be sold out. Are they still available?
Maybe send the seller a PM.
Following up I do think this amp has lower noise and better low level detail than my wiener monos, but not as full in low frequencies. Seems to have a little better separation of instruments and depth. However, the monos have more bass output. Otherwise the 3251 has the same sonic attributes. The 3251 has more power though and since I may pursue more power hungry speaker builds in the future, I will probably keep it as my main Amp!
Great job, 3eaudio.
I did email him thru eBay & he stated that the group might notbe available until Mid-May. So some good news.
Great. I think this amp sounds terrific.
the 2nd version had been released now.
both of Power input and Speaker Output connectors were changed to SCREW type for easier assembly.
TPA3251D2 2CH Class D Audio Amplifier | eBay
Looks like TPA3255 and TPA3250 amps will be offered soon as well at 3eaudio website!
Already there Looks nice
yea more stock now, all 3 boards available!! yay! i think ill get the tpa3250 and tpa3255
Wich one is best suited for 8 ohms speakers ?
Depends on the power level you want. Look at the datasheets for the amplifier IC (chip). The word TPA32/50/55/51 is the name for the amplifier IC. Search "<Amplifier IC Model Name> Datasheet"
http://www.ti.com/lit/ds/symlink/tpa3250.pdf
http://www.ti.com/lit/ds/symlink/tpa3251.pdf
http://www.ti.com/lit/ds/symlink/tpa3255.pdf
heres the first page of one, which i have commented on to help you. note theres you will normally finds pages of graphs about useful info about the amplifier IC if you scroll down the datasheet. which i advise you to do. I always look for the THD v.s Watts @ powered at recommended input voltage.
https://www.pic-upload.de/view-33515158/tpa3255-THDExplained.png.html
direct link to image: https://www2.pic-upload.de/img/33515158/tpa3255-THDExplained.png
New TPA3255 amp
https://item.taobao.com/item.htm?sp...xDtm9&id=555203865367&ns=1&abbucket=20#detail
How to translate this page into English?
I have some questions about this thing..
1. Can it run without problems from a linear supply - bus pumping etc? Any tips as to precautions with linear supply?
2. Can the coils cope with low impedance (4ohm) load at high levels and is this suitable as a full range amp for something like, say, an inefficient Dynaudio 6 inch bookshelf speaker.
3. How is turn on/off thump etc?
4. What do you guys do about speaker protection?
I'm wondering if this is a nice alternative to an Icepower 125 or 250 type board.
google translate or chrome browser will do it automatically
Thanks.google translate or chrome browser will do it automatically
The datasheet of 3251 does not talk about 8 ohm speakers, whereas the datasheet of 3255 does. Does it mean 3251 is not suited for 8 ohm speakers, or just that TI has not written about it?Depends on the power level you want. Look at the datasheets for the amplifier IC (chip). The word TPA32/50/55/51 is the name for the amplifier IC. Search "<Amplifier IC Model Name> Datasheet"
If you could release boards with unbalanced inputs, it would be so much better, as a lot of us still dont use balanced inputs.
According to his website, the boards have a jumper selectable option of both balanced and single-ended input.
- Vendor's Bazaar
- TPA3251D2
