TPA3116D2 Amp
yes small nets apparently more Sanwu's have that
It is that I obtained an excellent Wadia amp or I would have made a PCB with either 2 x TPA and PSU but more likely an FDA with STA326 and on board SMPS. I started with the latter. In most cases the chips will be used with 1 PSU anyway. I saw a challenge in making it very compact but I stopped putting time in it.
Nobody told you what to do but I seriously ask myself (in general, not adressing to you personally) why boards with TPA are mono mostly and without PSU. Maybe to sponsor Meanwell 😉 The silly small size of boards is no benefit when a large PSU is needed next to it. Secondly SMD ceramic input caps are needed then while better 2.5 mm small TH film caps exist.
