See TI 3116evm, 330pF and 10R.
Sorry to be thick in the head, but I don't know where you are sending me: to TI website or to diyaudio with those parameters in the search?
I am like two mods behind some of you, esp. since people are now using input transformers. I want to try the snubber mod next but had zoned out when most of that discussion was going on. Is there a chance that someone can update the Wiki to show the list of parts and links to those great pictures people posted of the mod?
I have this in my personal notes (that I will some day get around to adding to the Wiki): post #3823 by xrk971 on July 13, 2014 has both the TI eval board circuit and pics of his own implementation of the snubber mod.
Note: exact-post URLs are a little tricky on this forum, because users can adjust how many posts they see per page. I have my settings set to the max (50 per page I believe) where the default is IIRC 10 per page. In my view, this entire thread is only 93 pages long, whereas it's significantly more pages to someone using different post-per-page settings. In short, you may have to track down that post by date and/or post number.
I am having a bit of a ps. problem with a 19v laptop ps. It works great with the YJ blue/black boards and a 5.1 board I'm working on. It does not work with either the YJ red board of the one in my previous post. There is a very quiet clicking noise and that is all.
Any ideas why?
Any ideas why?
Prezen, I have that amp board. I have done a mini review on this board some pages back with pictures! The original caps are too far from the chip so upgrading them helps only a little. I put in better alu caps which helped to some extent. I suggest you take off the cooler fin and solder oscons directly onto/close to the chip to get true dynamics. Afterwords you could shorten the with of the cooler and glue it back on. I really love the mute function and the good output filter🙂
I just read your post. That is a fantastic (and advanced looking) mod!
I think this amp really is a bargain and is easy to modify. I changed out the 10 DC power caps on the left side and replaced them with 470uF 35V Panasonic FM caps, I found it made a difference in clarity and noise reduction.
I tore out a trace on one of the little caps between the heatsink and the red WIMA input caps at the front, and i found it difficult to route around it so I gave up and went to work on other things in the meantime.
Where to buy OSCON's capacitors. Price in Mauser is 1.5$ and 90$ to send to Serbia. Nuts.
This are 2 peaces 7$
2 Sanyo SEPF 25V 330UF Small Size High Voltage OS-CON Aluminum solid Capacitor | eBay
Same question. This can be a solution?
Elkos Aluminium Elektrolyt Kondensatoren - SMD - verschiedene Werte | eBay
or
10x SMD Elkos Elektrolytkondensator Panasonic 330?F 25V 10x10mm | eBay
or
20x SMD Elko Kondensator 330?F 25V 105°C UUX1E331MNQ1GS 330uF | eBay
Thank you for your help!
or
or
Romania has Elfa Distrelec, shipping must be checked but for me small order shipping is around 6 euro, sent from Elfa Sweden warehouse.
(re Ebay: first link #4644 It-tronics SMD cap. Print on this cap is exactly what impuls's 2004 Panasonic FK print should look like according to Panasonic 2004 FK datasheet. Not the letters, but the layout. The linked FK3300 ebay link, and impuls's foto's show a FK3300 looking like Panasonic 2014 FK datasheet, but text says produced 2004. In itself 2004 tells you the FK electrolytic-cap has been shelfed for 90.000 hours, and not to expect datasheet values when measured.)
Regarding prefilter snubber, bootstrap snubber. Can somebody tell me how it sounds different and which ampboard they added the snubber?
Elfa Distrelec - 25SVPF330M - https://elfa.se/elfa3~ex_en/elfa/init.do?item=67-141-76&toc=21524
They do not have 25SEPF330M
2 Sanyo Sepf 25V 330uF Small Size High Voltage OS Con Aluminum Solid Capacitor | eBay
25SVPF330M https://www.distrelec.com/ishopWebF...rch.do?dispatch=find&keywordPhrase=25SVPF330M
25SEPF330M or 25SVPF330M ???
I have done the snubber mod to 3 blue/black boards. Unfortunately I made other changes at the same time so cannot say if this was the snubber mod specifically. The other mod was changing the LC filter to values reflecting the speaker impedance.
Anyway the mod appeared to improve the mid/high frequencies in particular, sounded more refined, less grainy.
Do they have normal shipping prices to Serbia? Officially still outside EU I think, that might be problem for shippingscales?
V package is a little different, leadwires are flat and 0.8mm (vs 0.6mm), the hybrids only come like that I believe, haven't had problem mounting them through hole, but when holes aren't clean that could be harder. Had them on YJblue and Sure3110 and Hiampmini without problems.
Thxs. I ask because I replaced resistor on output snubber YJblue for 3.3 ohm and wondered if that gave similar result. Others with observations about how sound changed using the prefilter snubber or from changing the outputsnubber resistor into datasheet value??
You mean the original on the YJ/blue board is not 3.3ohm?
Just looked at a YBDZ board - they definitely are 3.3R.
How about solder the oscon cap on those 2 104 SMD caps?
Try to contact Mikroprinc.Where to buy OSCON's capacitors. Price in Mauser is 1.5$ and 90$ to send to Serbia.
They work with Mouser 😉
I just ordered 4 pices of OSCON's.
- Class D
- TPA3116D2 Amp
