Does anyone know where I can find a round can for potting a toroidal transformer? I'm not planning to seal it with epoxy and leave plenty of ventilation holes on the bottom for heat generated.
I thought this is the most appropriate place to ask, because we are the ones who love to mount things on top of chassis 🙂
I think you are on the right track, I did some mu-metal shields and then completely encapsulated them in epoxy. It was more trouble than it was worth.
For small toroids (<100 VA) I am looking at using speaker driver shields, either bought or salvaged. I, too, would be interested in a source for covers/shields for larger toroids (300 to 400 VA).
Speedy metals (https://www.speedymetals.com/default.aspx) will sell you a chunk of aluminum in many different diameters, thicknesses and whatever height you choose. It's an inexpensive fix if you have the flexibility to mount using a bracket or tiny bolts.
I used a stainless steel outdoor cup as can for a transformer...but they only come in diameters up to about 10cm.
These are only small...
VT4C
80mm (3.15") Diameter External, 70mm (2.76") diameter internally
50mm (1.97) Tall, 36mm (1.42") tall internally
Weight :315 (gram/Set)
Size (mm): 80 dia x 50 tall
$12ea + shipping from Hong Kong
VT4C
V
Vek
You can also get it here:
http://www.askjanfirst.com/
They have two versions, one made from metal (http://www.askjanfirst.com/kb/TRAZ10.jpg) and one made from polyamide (http://www.askjanfirst.com/kb/TRAZ20.jpg).
Greets
Greets
Re: These are only small...
This must be a sure no-no
With the center thru-bolt it will create a shorted turn
I don't believe the bolt is intended to touch the enclosure top...
Hopefully the top is a "push fit" onto the bottom.
there was a site in HK that had loads of transformer cans in various sizes - they were on Ebay listed as "chassis".
Typically, I cannot find the reference!!!
VT4C
I knew about the round can from VT4C.com but they are far too small to even fit a 20VA toroidal transformer.
Greets
I am trying to pot a 160VA or a 300VA and thought that http://www.askjanfirst.com/ as suggested by Vek, but shipping quote was unimpressive for a single plastic pot.
I like that approach 🙂 Is there any other everyday life objects that can serve as a good looking potting can?
How about tin cans
I use small coconut milk tins for shielding the tubes in my octal phono stage.. Some cans dont have the ribs and the join could be put to the back.
Just a thought.
p.s. Please remember to eat the contents of the can before potting
Just a thought.
Cooking pots & pans?
They are a bit too thick for potting, aren't they? Not to mention handles attached.
I wasnt kidding
Hi james
The tiin cans i speak of dont have handles and could be made to look alright.
How large is the tranny you want to pot?
Nick
Hi james
Nick
- Tubes / Valves
- Toroidal transformer potting can
