Well, someone started this thinking they could mod it to improve it. Its just that I suppose. I'm good with Nc400 monos thank you.
I agree with you ... and also why modify an amp if from the start there does not seem to have good reasons to do so. This thread is useless after all ... lol
??? Of course the pinout differs for the TAS5613 and that's why JohnY said it won't work when you replace it with a TPA325x, quote:Nope. TAS5613 DKD pinout is absolutely different.
"Also to those of you who are convinced PA5 used certain chip [the TPA325x], you can hot air replace one onto it and see if it functions normally. It can not would not."
TAS5613....
This 10-year-old chip .... I think you are getting lost ...
A revolution with old chips ...
Topping will have good reasons why they chose this chip. Those reasons are unknown to us, of course.
It is yet to be verified .... Whether it is this chip ...
I highly doubt it.
It's clear ... If it's this chip ... I'm not buying!😕
I highly doubt it.
Exactly.What would the chip used matter? Isn’t it the end result that matters?
We must go in the direction of technological evolution ... Class D is constantly evolving.
Recent chips have certainly corrected the faults of their elders.
If not, research and development will be irrelevant ... No😢
Unless the evidence photo was photoshopped (and the poster who posted it was a sock puppet of Topping trying to seed misinformation) I see no reason for doubt.It is yet to be verified .... Whether it is this chip ...
I highly doubt it.
Whatever chip is used - the secret may be found in a very clever way to apply postfilter feedback. And yes, the TI proposals of PFFB are not that great.We must go in the direction of technological evolution ... Class D is constantly evolving.
I’ve been a little cautious when interpreting the results from the scientific site, have seen the worst external smps supplies used there to test DACs, was something left over from a rechargeable power tool or something.
That likely wouldn’t be as much of an issue with a TPA32XX, but still causes me to take the charts and graphs with a grain of salt.
That Topping amp looks like a decent product, making the best of the TPA chip.
D
Deleted member 148505
On the picture of the chip used, you can clearly see the pinout of xVDD supplies, the IO and ground pins as well as other components. The circuit is pin by pin compatible with TPA325X.??? Of course the pinout differs for the TAS5613 and that's why JohnY said it won't work when you replace it with a TPA325x, quote:
If you replace it with TAS5613 it will go into flames since PVDD supply and speaker out pins are different.
You need to find another chip that is pin by pin compatible with TPA325X because the board pinout and PCB trace is for TPA325X.
Yes looks like it is well protected in the potted section.Whatever chip is used - the secret may be found in a very clever way to apply postfilter feedback. And yes, the TI proposals of PFFB are not that great.
Avez-vous lu ce qu'on m'a dit à propos de la puce ? Vous pouvez également vérifier à partir de ASR > Tpa325X .So no one even knows what the amp chip is much less what mods can be done. This is just a product hype thread.
Hi Jlester,
What would you guess under the D01 black box ? Some differential OP amps ?
I think you have more expertise than mine ... Topping kept this part a secret.
Under the PCB, we count 9 pins under the D01 box :
Well, now we know for sure that any "reviews" / listening test from you can be safely ignored.
They are obviously biased by your technical insight (correct or not) of the thing infront of you.
I see you point wrt pinout, checked it and stand corrected.On the picture of the chip used, you can clearly see the pinout of xVDD supplies, the IO and ground pins as well as other components. The circuit is pin by pin compatible with TPA325X.
The marking we see in the evidence photo is not the model marking (which has been sanded off), it another marking (date/lot code etc) that happened to similar to the TAS5613 but not quite (as it reads 56131 and not 5613 alone)
Another 3255 pic with that additional code, appearing to be 56163
I own almost all Class D amps, Purifi, Dual Merus, Tripath, high end TPA325X, Mini Gan etc
You just have to understand that few people can put 1400 euros in an good amp..I am the first to be convinced by Bruno's products
BUT best price for Purifi in Europe = Audiophonics = 1400€
The Topping is neck and neck VS the Purifi and costs only $349 (I think at this price we can excuse some minor flaws)
it's 4.5 times cheaper....
Neck to neck? Absolutely not. ONE single parameter is better, and it is indeed impressive, but it offers a fraction of the power, and distortion is worse elsewhere, and it raises significantly more with frequency. Do not misunderstand me, the PA5 is a little miracle, but it is obviously not in the same league as proper Purifi 1ET400A implementation and the Benchmark AHB2. Not even remotely.
Scientifically it's true .... but I doubt your ears will be able to measure what a measuring instrument perceives .... If I blindfold you and place the 5 best amps in the ASR ranking, I can make sure you won't see any difference.
Would you be ready to spend 1400 euros to dispose of the imperceptible?
My last question is : do you own the Purifi ? Do you own the AHB2 ?
https://audiovoodoo.plScientifically it's true .... but I doubt your ears will be able to measure what a measuring instrument perceives .... If I blindfold you and place the 5 best amps in the ASR ranking, I can make sure you won't see any difference.
Use the translator and read to yourself 🙂
For example:
https://audiovoodoo.pl/altmann-tube-o-lator-lacquer/
ALTMANN "TUBE-O-LATOR" LACQUER
Published on 2016-01-31
The producer boldly admits that he has no idea how it works. The only guess is that the energy of the signals causing the unpleasant sound in the varnish is converted into micro-vibrations and, consequently, into heat. Lubricate the transistors, converter, single-circuit amplifier, wait a few days and enjoy the tube sound of your equipment.
- Class D
- Topping PA5 (TPA325X) : Is a modification worth it? ?
