stan.
you need to find out what paper size(type) your copy shop can print.
for instance in europe we use A0,A1,A2,A3,A4 ect.
whe need minimum of 30"*30" but beter is 35"*43"
u only need 1 print .
the rest is straight lines wich can be measured.
behold of the toptap.
i got 3 different type of print files for the copy shop .
i put a line on it with measurement so you can check if its a 1 on 1 copy.
all pannels 12 mm except pannel 1 and 2 are 18 mm.
http://seijs22.home.xs4all.nl/toptap print-Model.dwfx
http://seijs22.home.xs4all.nl/toptap print.dwg
http://seijs22.home.xs4all.nl/toptap print.dwl
and full size httphttp://seijs22.home.xs4all.nl/toptap print-Model full size.dwfx://
Thanks a lot erik
The carpenter went away for fews day so when he return I wil show him all the plans
How much sheet of ply to make the top
So with the size of the print I can put the paper on the plywood and copy the plan to the plywood
you are using xp?
you can view with xps viewer.
you need to download .net framework 3.0
see if your print shop can open them.
its probably a lot easyer for the carpenter , if you make a print of the sub to,so he can check 1 on 1 if pannels and corners are correct.
you are using xp?
I am using windows 7
I wil not get to the print shop this weekend, I am working this weekend but i will call the print shop and ask what type of file can they print.
u use behringer dcx2496 processor?
use the settings as in example page 22 in the manual.
use 18db butt. @100hz or 24 db lr for low/mid x-over,and 18 db butt 1000 hz mid/high to start with.
use auto align function first to get you started.
Yes I use the dcx2496 processor.
Looking forward to seeing some real world measurements 🙂
Thanks, waiting on the carpenter to return to get a price for the cabs to be build
Did this top ever get built?
Hi Erik - I'm lookin for a really nice and beautiful sounding diy top. I searched your name and found this thread. Hope all is well, guys & gals!
Hi Erik - I'm lookin for a really nice and beautiful sounding diy top. I searched your name and found this thread. Hope all is well, guys & gals![/QUOTE
Money trouble😡
- Top for tap
