Top for tap
stan.
you need to find out what paper size(type) your copy shop can print.
for instance in europe we use A0,A1,A2,A3,A4 ect.
whe need minimum of 30"*30" but beter is 35"*43"
u only need 1 print .
the rest is straight lines wich can be measured.
behold of the toptap.
i got 3 different type of print files for the copy shop .
i put a line on it with measurement so you can check if its a 1 on 1 copy.
all pannels 12 mm except pannel 1 and 2 are 18 mm.
http://seijs22.home.xs4all.nl/toptap print-Model.dwfx
http://seijs22.home.xs4all.nl/toptap print.dwg
http://seijs22.home.xs4all.nl/toptap print.dwl
and full size httphttp://seijs22.home.xs4all.nl/toptap print-Model full size.dwfx://
you are using xp?
you can view with xps viewer.
you need to download .net framework 3.0
see if your print shop can open them.
its probably a lot easyer for the carpenter , if you make a print of the sub to,so he can check 1 on 1 if pannels and corners are correct.
you are using xp?
I am using windows 7
I wil not get to the print shop this weekend, I am working this weekend but i will call the print shop and ask what type of file can they print.
u use behringer dcx2496 processor?
use the settings as in example page 22 in the manual.
use 18db butt. @100hz or 24 db lr for low/mid x-over,and 18 db butt 1000 hz mid/high to start with.
use auto align function first to get you started.
money is a bitch sometimes🙁
so were designing something else with what we have atm being a selenium 15sws800 and a celestion bx12" 4805 🙂
the selenium wil cover ~80>~300 hz and the celestion above it.
i got this sofar
