Tony Gee's Capacitor page updated..
Hi Scott,
In the Doug PCB, I putted all the long leads to the + of the markings as I have no clue !
It matters and it does not matter. Don't ask me the details because I don't know them. What you can look up is the super E-Cap configuration, where the fictional + and fictional - of bipolar caps are combined. It's a black gate thing, I haven't tried it.. but it might help you in your quest to know more about what you did. I would have done the same as you did by the way.. 😉
Here is a pic of my busted cap
(Can't even embed right!)https://drive.google.com/file/d/0B-Yz9ZAviLOLSDFRV1RiZTNURzA/view
Great feedback! Thanks! In the US 🙂
So I should go here:
https://www.parts-express.com/dayton-audio-dmpc-15-15uf-250v-polypropylene-capacitor--027-432
Or stick with 100V rating on el-cheapo:
https://www.parts-express.com/15uf-100v-electrolytic-non-polarized-crossover-capacitor--027-344
Should I change the cap in the other channel to match?
With the electrolytic bi-polar as the green Muse ES (Nichicon), I see there is a longer lead for the positive pole I assume.
Does it mean they can be used at reservoir caps or behind a rectifier in shunt position to the pcb gnd ? Does the sense is important as they are bi-directional or should they be avoided at such use ?
Has anyone an idea about this please ?
Bi-Polar electrolytics are roughly twice the size and twice the cost of polar electrolytics fr or the same capacitance.
Bi-Polar are generally not available in large capacitances.
For those three reasons one rarely, if ever sees Bi-Polar recommended for PSU smoothing duty.
Indeed...😀
I was thinking to a concrete design where I need only around 1500 uF / 16V after the rectifier bridge. The Nichicon Muse ES bipolar have its biggest cap at 1000 uF /16 V... which is enough in my situation. to low for an amp but if you make one à la Sphinx Audio (Dutch or Sweeden ? iirc).... they didn't use bipolar but normal 10 x 2 000 uF caps if I remember in one of their amp.
If it is bipolar then it doesn't have a positive pole.
Sometimes in electronics it is possible to get away with using an inappropriate component, such as a bipolar cap in a polarised circuit location. There is no advantage in using an inappropriate component (apart from convenience if you happen to have them already in stock at home).
But apart having them in stock or the higher price, is there a danger or a weakness (aging ?) to use a bipolar at such a place ? (at least when benchmarking with the same near characteristic : for instance if both are 85°c for instance and not long life)
Hi Phase,
Sorry, it's above my knowledge and I haven't exerienced it already ,
I try to understand your answer: take a radial cap with the same space between leads :bipolar and a non polar due to their internal construction have different inductance ? (i.e. : bipolar have a > inductance due to its bidirectional construction = same having a more space between the two leads vs a non polar radial cap ?)
Bipolar electrolytics are not two capacitors back to back, although they do have two oxide films back to back (with electrolyte between them). The inductance would probably be about the same, and in any case inductance is not an important characteristic for a PSU reservoir cap.
It is still not clear to me why anyone would choose to use a bipolar cap for a PSU. It has no advantage, so why even consider it?
