Hello--
Finally looking at the Audiovox AVX-900 as the ole Craig that got fixed sounds just awful. Current symptoms, when the power is turned on, no response from the buttons, display (inverted), tape deck constantly spins and ignores input. Poking around, at least the top two blue capacitors have leaked, and I am going to assume the rest of the blue ones have. Audio amps are a paired NEC C1182H-3, C1181H-3(?) (cant see it), tuner is a toshiba t1400-U with an iron core tuner. I havent dug around the rest of the radio, but I am going to assume all blue caps will need to be replaced. I know its really up to me, but based on the hardware, would it be worth it to save this radio? It concerns me that not even the display turns on...
I think the first thing you should do is to get the radio out of cassette mode and into AM/FM. Is the cassette deck in the position that allows you to insert a cassette?
I already tried putting a tape in and out of it multiple times with no luck. The micro switch for the tape deck connects directly to one of the leaking capacitors. I can check tomorrow with a multimeter to see if the switch itself is working.I think the first thing you should do is to get the radio out of cassette mode and into AM/FM. Is the cassette deck in the position that allows you to insert a cassette?
