To Raspberry Pi/BeagleBone Black/CuBox/UDOO owners: RuneAudio is looking for testers
Thanks for the clarification, so Michelangelo wrote Raspyfi OS and you wrote the WebUI used in it, then went on to write your own OS and reuse your work on the UI...
Not to take anything away from either Michelangelo or the Rune Team, but technically, neither of them "wrote" the OS that either Raspyfi/Volumio or Rune is based on. They each created a Linux distro around existing Open source software(Volumio may be based on Debian/Voyage, whereas Rune is Arch Linux based), with the WebUI being created by the Rune Team..
Thanks for the advice. I was thinking of a stand alone system, but looks like I'd better start saving....and learning.
I wrote my original reply based on the mistaken assumption that you already had a BBB. Since you don't, and want a single box solution, you might want to have a look at a Cubie Board 2. Rune don't have a distro for it yet, (I was going to bug them about helping with the porting process since I have one in my hands), but one nice thing is that there is a SATA port right on the board, and if you buy the right Kit, you can get all the bits and pieces you need for under $90... (case for the cubie board itself, power supply and cables (including a SATA cable)).
It does not have I2S out, but it does have SPDIF and USB, and it is considerably more powerful than the RPI or the BBB.
Have you tried to switch kernel profiles under MENU > Settings in the RuneUI? You could find the best system settings for your setup.
Yes I do but will go further when ALSA out resolved/optimized
I'm going to investigate this.
Just to help, volumio... has nearly the same behaviour.
Amanero accepts only S32_LE (I configured it as 32 bit) so 16bit,44.1 Khz is converted to S32_LE. This is where sample rate seems to be converted at 48Khz
Plug PCM: Rate conversion PCM (48000, sformat=S32_LE)
Converter: linear-interpolation
Then it uses Slave: Direct Stream Mixing PCM to adress the Amanero Card.
I already have the solution to avoid sample rate modification and not using Direct Stream Mixing. It is to "write" a specific PCM default plug in with hw access to Amenero (in asound.conf).
But it interests me to know if others experienced the same thing "out of the box"
Hi Andrea
I'm happy to see a next-door neighbor developing a so interesting project...🙂
I've downloaded the rPI version, but I found out that it do not support I2S out.
Do you have plan to release an update with this function enabled ?
I'm already using rPI with an I2S DAC and wouldn't go back to USB. Quality wise I2S is much better and no any glitch.
Hi mvaldes, we are almost neighbors 🙂 We plan to include I2S support very soon, in one of the following releases. I would be happy if you could help us with testing. Ciao!
The default (stock) alsa configuration of the device "default" is either the pulse plugin (for pulseaudio-enabled distributions), or the dmix as fallback. If you want to communicate with the soundcard directly, use either hw:CARDNAME or more flexible plughw:CARDNAME.
I quote Vincent Kars here:
Playing 24 bit audio on a 16 bit sound card is not bit perfect by design.
The samples must be converted to 16 bit and dithered.
Playing 16 bit audio on a 24 bit sound card is a matter of adding 8 zeros to the sample.
This won’t affect sound quality as no information is discarded or added. (The Well-Tempered Computer)
The same applies to 32 bit output (16 zeros are added).
On the other hand converting 44100 to 48000 is resampling and alters the information.
To check if you are playing bit perfect, go to http://runeaudio/dev.php and enable debug mode (defcon [1] (sys+MPD) is enough, and disable Hide debug informations).
You will see something like this:
PHP:
interface #0 stream status: (/proc/asound/card0/stream0)
Schiit Schiit USB Audio Device at usb-bcm2708_usb-1.3, high speed : USB Audio
Playback:
  Status: Running
    Interface = 1
    Altset = 1
    Packet Size = 392
    Momentary freq = 44131 Hz (0x5.8433)
    Feedback Format = 7.17
    Packet Size = 0
    Momentary freq = 44100 Hz (0x5.8333)
  Interface 1
    Altset 1
    Format: S16_LE
    Channels: 2
    Endpoint: 5 OUT (ASYNC)
    Rates: 44100, 48000, 88200, 96000
    Data packet interval: 1000 us
  Interface 1
    Altset 2
    Format: S24_3LE
    Channels: 2
Check if the Momentary frequency value is the same of the source file.
Thanks Mr.Slim....great advice. I think I'll lurk for a while, do more homework re other options, and watch out for a Rune distro.
@phofman, thx I didn't know that Pulse or dmix was the default device as under Ubuntu/Clementine (or deadbeef), I always specify hw:... as ALSA output.
@ACX, This debug log is What I looked for 😎
And sorry, i did not share that I knew that only resampling to 48KHz alters the sound. I choose 32 bit for my USB amanero input so it only accepts S32_LE as input format. Thus soft Player or ALSA will always have to add Zero (if not 32 bit sound) or convert from little Endian to Big Endian or vice versa (depending on physical device used) if necessary. And of course can still be taken as Bit perfect 🙂
Use debug mode and can confirm no resampling.
I use orionV2 kernel mode + Buffer, may be now one or two click left.
Overall sound quality is really good, but i think it's worth using more powerful device than raspberry.
We founded RuneAudio (rebuilding the distro from scratch based on Arch Linux) and Michelangelo founded Volumio (using our work of the webUI, in which he hadn't written any single line of code before that). That's why you can find our webUI in 3 different projects. I have to clear this point because most people does not know who really is behind that huge work and even thinks that RuneAudio is a fork of Volumio, when the concrete is quite different.
Hi, ACX,
Why you choose Arch over Debian?
Daphile also uses your WebUI ?
I'm interested in software running on the Raspberry Pi
Hi ACX
A couple of things that I'd be interested in seeing - support out the box for the HiFi Berry DAC and Raspberry Pi combo.
  • An option to select inputs on the UI from USB A, USB B and HDMI
  • Video out via HDMi using Airplay - I know this is an audio project but hey it's there...
  • An automatic WiFi hotspot that would allow discovery log on and connection to a network out the box and via the web app with no need to conect keyboard or monitor to the Pi
For me this last one is a killer feature
