Hi Jan,
did you manage to get the residual with Vertins?
I look for this possibility urgently also a long time….
thanks for any answer!
Jenerg,
Yes you have waited a long time here...three and one-half years. Along time.
Anyone have any updates? I am interested too. Just haven't been waiting
that long.
that long.
I am in contact with David from Virtins. I got already a very nice recommendation from him how to get the residual.
After some time to get acquainted with the program I got indeed a result.
It shows clearly the k2 dominance for example of the Aleph 3 but the phase information, k2 negative or positive seems not to be stable over the shown time.
I reasked David, I think he will answer next week at least.
Either I made a fault or the affair is still more complicated, possibly as Jan showed in his last posting you have to choose the fundamental not free but in correspondence to other values. I will try this next days.
…..here comes the explanation how to get the residual picture out of the distortion data with Virtins Multi-Istruments software inspired by Jan Didden.
Big thanks for the patient explanation over three days from David (Virtins help desk).
If you finds faults or recommend changes I will do this in the pdf.
and you can see some of my measurements with Virtins here
http://www.diyaudio.com/forums/pass-labs/267857-aleph-design-reloaded-27.html#post4807775
with my Aleph3 clone thanks to Pa!
Hm, there is still a problem.....
Look here
http://www.diyaudio.com/forums/pass-labs/267857-aleph-design-reloaded-27.html#post4807889
Either my hardware or the software....
The search goes on......
Look here
Here might by the explanation for the difference that Mr. Pass mentioned....
David from Virtins wrote me just again and will try it these days and implement David's correction for phase looking in the PDF!
"Hi Gerd,
Sorry, I forgot to mention one thing, if you want to compare the filtered data with the original one and make them time aligned, then please note that a FFT filter will not cause any phase shift (i.e. the filtered data are time aligned automatically with the original one), *while the FIR filter will cause a time delay of [FIR order]/2 * [Sampling Interval].* That is, if you use the 1022nd FIR filter window, the data will be delayed for 511 points. *To make the FIR filtered data time aligned with the original waveform, after FIR filtering, you need to go to [File]>[Extract], and save a wave file from the 512nd point to the last point.* Then when you combine the original one with the FIR filtered one, they will be time aligned. **If you are more interested in the phase comparison than the amplitude comparison, probably FFT filter is more convenient.
Best Regards
David"
I am happy he wrote this, it saves me much experiments I planned.
"Hi Gerd,
Best Regards
David"
- Design & Build
- Equipment & Tools
- Time-view of distortion residual
