TI TPA3255EVM
To round this up, heres a simplified simulation of using a 22uH inductor at 52kHz in buck-configuration with parameters set:
VIN: 40V
VOUT: 15V
ILOAD: 50mA
Filtering is done by 1 MLCC 1uF + some random 100uF elyt capacitor, resulting in a 50mV ripple after filtering or 0.05% of VOUT.
I don't know the values used on the chinese boards but i suspect it's not less than 100uF.
This is then feed into an LDO with filtering.. before the opamp (with filtering as well).
Spice is attached.
  • Buck_52kHz_DCM.asc
    Buck_52kHz_DCM.asc
Let's really not go there as that's more a philosophy than a real design constraint, okay? As it stands, the evm gets pretty great performance with a.c. coupling and ancient opamps used as input buffers. 🙂
Edit to add you'll need to have it a.c. coupled before the 3255 anyhow as that's on single supply, so its a matter of where rather than if.
I haven't calculated against the EVM implementation, but yes, the coupled inductor (Coilcraft) is more expensive then standard (random) inductors. Beside that, our implementation is much smaller (170mm^2)and works up to 100V. As we tested several AFE (analog frontent) designs, +/- supply was/is nice to have. Due to high frequency, filtering is much smaller (if needed) and can be done with ferrites and MLCC. I'll reuse the design for other projects. It's also easy to adapt to an isolated AUX supply.
Long story short, it is sporting interest. 🙂
