The XCEN -- Balanced to Single Ended Converter
Gents, tweezers might help a bit!
No need for an especially pointy tip or fine solder either IMO. You want a reasonable size tip actually, if you are soldering anything with a large ground plane, your pointy tip will drop temp too quickly and have you leaving the soldering iron in place for too long.
A good light in the area helps a too.
<laughs> A few years ago I designed a complex central controller system for an Epson product, which included a number of innovative features including phase-sensitive decoding of motor state. When I brought one of the prototypes in for demonstration, primarily the clients were impressed that I had assembled it myself, as it was mostly surface-mount. They seemed much less impressed about the design, or that it worked 😀
For most parts, my technique is to apply solder to one pad, slide the part held by tweezers to the edge of that pad and reflow the solder as the part is positioned. Then it's a simple matter to solder the rest of the leads. If the lead pitch is really small sometimes you have to allow solder to bridge a few leads and then wick away the excess thereafter.
Here are some pictures of the test setup. On the scope you see a 10kHz square.
So test results of both prototypes as follows. It could not have gone more smoothly. 🙂
The circuit uses pre-calculated values of potential divider of the TL431s to account for the different Vgs of the Zetex MOSFETs.
Power supply was my lab supply, +/-24V, no on-board caps on the rails.
Supply cables are about 1m long.
On power up, DC offset was about 100mV, and no oscillations were observed with inputs shorted to Gnd.
The DC offset went down to about 30mV after 3 minutes.
Once it stabilised, the offset value was converted (by calculation) to trimming resistor values.
These were then soldered onto the PCB (1206 SMD resistors).
After trimming, DC offset at power up is now about 50mV, but dropping to less than 3mV in 5 minutes.
Within the next 20 minutes, it fluctuates between +/-5mV.
This corresponds to an offset current of 2.5µA at a total bis of 40mA for the entire circuit.
The TO92 JFETs and the E-line MOSFETs are at about 50°C at steady state, even though dissipation is only 100mW or so.
I am very confident that this can be improved by a factor of two by thermally coupling all devices to a heat spreader.
This we already planned from the start, but we wanted to test first before getting it manufactured, as it does add cost.
On top of the spreader (and the top of all FETs), will be mounted a CPU type heatsink of 45x45mm.
This will not only allow the different devices to track each other thermally.
It will also lower the overall temperature with the aid of the large heat sink.
And the thermal mass of the spreader and the sink will even out fluctuations with time.
As such, I personally do not think a servo is necessary, even though it can be added easily on an additional PCB underneath.
I can even live with 5mV as is.
The rest of the test is essentially same as Joachim, and same on both of my prototypes.
Bandwidth is -3dB, 2MHz. Perfect 10kHz square waves.
Gain is as predicted but can also be trimmed easily by adding a trim resistor.
Distortion is much lower than 90dB on 2Vrms, and beyond my measurement capability.
So that would have to wait till I get my hands on an AP again.
We already did a version 2 of the PCB where the left and right channels are mirror images.
And we also added electrolytic caps for the rails on board.
Once we get the thermal management tested, that would be it, as far as I am concerned.
QED. 🙂
Patrick
PS
On the DSO plot attached, green is input (functions generator 10KHz Sq), cyan is output.
Vin- was connected to Gnd in this case.
