got my boards, tool a little over 2 weeks to get to me in Las Vegas.
Now I need to find the BOM on this thread so I can order the parts needed.
Is there still going to be a GB for the opamps?
Canadian Post comes through!
Shipped on the 4th, received today, in Florida, USA on the 22nd. Not too bad actually. Never know how long it will take to clear customs.
Thanks Owen!!
Thanks Owen!!
yeah i would perhaps be interested in participating, or perhaps even running a small gb for the lme49990, could get the buffers too, but i already have mine. who has their chips already? it would probably be better to have someone in the US do it to save shipping time. cost would not be high as they could be sent as a letter without issue, but for cheap shipping it would take a 1-2 weeks from here
Hi Guys,
As I mentioned earlier, I was quoted 10-12 business days for all shipping, and I know that excludes the time the parcels sit in customs. So far everything seems to be arriving on time though.
I'm glad most of you have received your boards and kits.
Regards,
Owen
Regards,
Owen
opc, please check email. need feedback on tc measurement results before i move forward. seems fine, but not sure if a little low or just because i matched at lower voltage than where you got 0.92
Hooray!
Got my kit in the mail this fine day, a very light snow, the first I've ever seen here. 😕
Time to stick everything together, but before I start I have to ask, does anyone else's C9 bump up against their phone jack? It's not a huge problem but it means that I can't mount that cap straight and flush.
Anyhow, thank you Owen.
not sure mate, havent seen any other builds yet close up really have we. my parts will be here in a few days and i'll let you know from this end; but i'm sure someone else will speak up in the meantime
I finally got around to looking at the parcel.
I wonder under the impression that this was going to be a full kit?
Apparently I was mistaken?
Where is the BOM for the other parts I am going to need.
Post 54 mentions what was included, post 27 gives reasoning(the rest of the parts may be more personal choice, local availability etc..)..
The BOM is in Post 77..
JD..
I wasn't trying to complain..
or if I was, it's more about the fact that the first post doesn't link to any of this...
but I guess thats a diyaudio thing.
it's more about the fact that the first post doesn't link to any of this...but I guess thats a diyaudio thing.
Yeah, you can't edit previous posts, most annoying!
No worries, I was just trying to be helpful too.. 😉
and yes, it's too bad previous posts can't be editied, to add useful info..
I am very glad to announce that my first SMD circuit came to life just now.
I started this project a bit because I want to try to use headphones, a bit because I wanted to have a good balanced to unbalanced converter, but mostly to challenge my manual ability.
I have to thank Owen and the others for the tips and for the good circuit. I just tested on the bench I am going to connect to my Buffalo+Legato now.
D1 is in the cue !!!
Thanks,
Davide
Thanks,
Davide
N-Brock:
The interference you're seeing between C9 and the headphone jack really depends on what capacitor you chose, how the jack is mounted, and what the mechanical tolerance is on that stub on the end of the jack.
If you take a look at the pictures on the first page, you can see that I've got plenty of room to mount the cap properly, but if you have larger caps or a jack that is particularly large, then it could be an issue.
If I were you, I'd file down the end of the jack (the plastic stopper part) to give yourself more room. I think the end piece is quite thick, so you should be able to take some off without issue.
Mr. Slim:
Thanks for fielding that question! I was about to trudge through the thread for the posts of interest, but just before I did, I noticed that you had already done it. Cheers!
Nikon1975:
Congrats! I'm glad the assembly went well, and hopefully it has helped convert you to a passionate supporter of SMD!
Do you have any pictures to post?
Owen
Mr. Slim:
Nikon1975:
Owen
sounds like some tips for searching threads need teaching; see in the top right hand corner of the page window there is a button, 'search this thread' enter BOM. it was never going to be a full kit though, that was mentioned on the first page.
all the same it is very annoying not being able to edit posts for such reasons, because projects change depending on what the group wants. also if you knew what the parts cost you wouldnt be expecting a full kit for this price. just the 2 buffers is about 25 dollars; its only a small pcb, but its pretty jam packed with top flight parts
@ opc have you seen my emails? sent the pics you wanted
hmm, opc where r ya mate? should have the rest of my parts to finish the wire on mobday and will be giving it a run with the public at next weekends brisbane headfi meet. still havent seen my pics i sent?
- Headphone Systems
- "The Wire" Ultra-High Performance Headphone Amplifier - PCB's
