You can pull the C41-C44 capacitors and solder the transformer secondaries in on the TPA-facing side of the footprints.
Or remove R11 through R14, and attach the secondaries to the "C41-C44" facing side of the footprint, keeping C41-C44 in circuit - though you're soldering to a surface mount pad instead of a through-hole pad if you do this. I'll see if I can squeeze in some through-hole "test points" to facilitate that mod.
Silly question, but the through holes for the Pro card Coilcrafts are far bigger than indicated on the recent board image, right?
BK
BK
Yeah, there's actually slots there, but the gerber viewer I'm using doesn't cut back the copper to the board dimensions, only to the drill dimensions.Silly question, but the through holes for the Pro card Coilcrafts are far bigger than indicated on the recent board image, right?
BK
The original PBTL card had big holes, as I wasn't 100% sure how to specify a board with plated slots. I've since successfully ordered a board with plated slots. Haven't gone back and revised the PBTL card yet to have slots, but probably will.
Understandably! How hard would it be to throw in some solder pads for them? And maybe some jumpers to allow the user to effectively remove the active circuitry in favor of the transformers (or even their own balanced preamp/buffer/whatever)?
Or maybe put the solder pads/jumpers on the wishlist for Pro version 2? 🙂
+1
Gmarsh,
My local GB has taken a life of its own and seems constantly changing and glowing. Up to now there are around:
16 x tpa3118 assembled
15 x tpa3250 assembled
6 x PBTL 3118 assembled
I will cut it off as soon as you announce the cost for the Wiener Pro.
Thanks. You've got a handful.
Also, do you take paypal?
Hello gmarsh,
hope I'm not too late for this run. Could you please count me in on a fully assembled stereo wiener 4 ohm with thermal kit and an additional 8 ohm stereo filter kit (shipping to Germany; Paypal would be possible too).
(just write me a pm and I hope payment will be there till monday)
I've been following your project for quite a while and all I can say is:
Thanks for your great work and efforts for making all this possible!!
Last post I found with the complete list (inlcuded my order at the end and changed ChuckT's order according to his post above):
Thanks in advance
DNW
loafimus: 6 x bare Pro PCB w/ microcontrollers
jonners: 1x stereo fully assembled Pro
Pyjamas Before Chris: 1x stereo fully assembled Pro
wushuliu: 1 Pair Assembled PBTL MINUS CONNECTORS - 4 ohm
hepmusic 1 stereo 3118 8 ohm fully assembled
rhing: 1x stereo Wiener 3 Pro, fully assembled + 1x stereo Wiener (both 8 ohm)
williamau:2 x Weiner Pro, fully assembled
BK856er: 1x bare Wiener Pro + microcontroller
shochu: 1x fully assembled stereo + filter & thermal kits
TigerFoo: 1 x fully assembled stereo 8 ohm + filter and thermal kits, 1 pair fully assembled PBTL 8 ohm + filter and thermal kits
boylah: 1xstereo 3118 8 ohm fully assembled
ChuckT
Fjd: 2 x [Stereo Wiener 4 ohm, fully assembled and tested, filter kit, thermal kit] + 2 x [PBTL Wiener 4 ohm, fully assembled and tested, filter kit, thermal kit] + 1 x [The Wiener Pro 4 ohm, fully assembled and tested]
Takayama69 a.k.a Anders Högberg: 1x TPA3250 all inclusive. 8 Ohm-version.
mabu0815: 1x Stereo Wiener PCB + 2x PBTL PCBs + 3x microcontroller
Gordon_lo: 2 x Stereo Wiener 8 ohm, fully assembled + 2 x PBTL Wiener 8 ohm, fully assembled + 1 x The Wiener Pro 8 ohm, fully assembled
rchan: 1x fully assembled stereo + filter kits
BBUK: 4 (four) x fully assembled stereo + filter and thermal kits.
lacro: 1 x 3118 Stereo Wiener 8 ohm, fully assembled
DNW: 1x Stereo Wiener 3118 4 ohm (fully assembled) + 1x thermal kit + 1x filter kit stereo for 8 ohm (shipping to Germany)
Thanks in advance
DNW
ChuckT
Takayama69 a.k.a Anders Högberg: 1x2CH TPA3118 + 1x TPA3250 : all inclusive. 8 Ohm-versions for both.
ChuckT
Almost got pricing done on the Pro. I won't call this the official number just yet.
Assuming I order 25 boards, the Mouser parts (every part except the output inductors) works out to almost exactly $85/card with 15% provincial HST added. Coilcraft parts brings this up to $111/card. Adding the PCB, shipping for those and amortizing the stencils/solder paste/TSSOP jig for programming microcontrollers/etc adds another $20/card ($131), paying myself $30/card to hand assemble them we're at $161 CAD. Budgeting a bit of excess to handle failed cards, 5 cards worth of mouser parts written off = $425, /25 = $17 bringing us to $178. Lastly, $5 for Paypal fees = $183 CAD.
So higher than expected... hopefully this is still reasonable.
ChuckT
jorem: 1x Stereo Wiener 3118 4 ohm (fully assembled) + 1x thermal kit
ChuckT
It is reasonable enough ..for me to change my order.
I take 2 boards of the pro instead of the just added
3118 stereo as an extra amp for my workplace.
Hi Gmarsh,
For the tpa3250d2, is the $20 bare PCB means bare PCB + microprocessor unsoldered, without smd capicitors and the dip switch for selecting oscillator freq?
ChuckT
fingerx: 1 stereo 3118 fully assembled + 1x stereo fully assembled Pro
ChuckT
$20 is bare PCB and a preprogrammed microcontroller in a static bag. You'll have to buy the other parts and install them yourself - all parts except the inductors are available from Mouser, the inductors have to be purchased directly from Coilcraft.Hi Gmarsh,
Sent from my Nexus 4 using Tapatalk
And thanks everyone for not revolting on the price 🙂 Still working out costs for everything else so that number may change.
Not too late. Still finalizing pricing - Sorry it's taking so long, got other things going on. When that's done, I'll have actual prices for things like filter kits for the Pro and I'll be able to actually start taking payments for these things.
The thermal pad for the Pro will be the same as the one on the standard Wiener cards. I went looking for bigger thermal pads I could put down, but it's hard to beat the 6 W/m-K of the H48G material.
fingerx;4699389]oafimus: 6 x bare Pro PCB w/ microcontrollers
ChuckT
Pinnocchio: 1x bare Wiener Pro + microcontroller
ChuckT
My name got cut off during a copy/paste along the way.
ChuckT
ChuckT
I will also jump in last minute.
ChuckT
harmolodics: 1x Stereo Wiener 3118 8 ohm (fully assembled)
ChuckT
- Group Buys
- "The Wiener" TPA3118 amplifier, group buy #3 + "Wiener Pro" prototypes.
