Andrea,
Do we really need the square converter for Ian's clock board? It has a clock buffer and should do the work for us.
All Ian's FIFO need CMOS clock, not sine wave, so you need to convert the oscillator's output to square wave.
Crystek, TDK, Pulsar and so on, are all CMOS output.
Interests list:
- andrea_mori: 1 x SC 5.6448 MHz + 1 x SC 6.144 MHz + 2 x TWTMC-DRIXO + 2 x TWTMC-EXO + 2 x TWTMC-DRIXO-XFMR + 2 x TWTMC-EXO-XFMR + 1 x TWRPS-UGL + 1 x TWRPS-pp
-hifoli: 1 x SC 5.6448 MHz + 1 x SC 6.144 MHz + 2 x TWTMC-DRIXO + 2 x TWTMC-DRIXO-XFMR + 1 x TWRPS-UGL + 1 x TWRPS-pp + 1 x TWTMC-STS-DX + 1 x TWTMC-STS-SX
-laserscrape: 1 x SC 22.5792 MHz + 1 x TWRPS-UGL + 1 x TWTMC-DRIXO + 1 x TWTMC-DRIXO-XFMR + 1 x TWTMC-STS-SX
-Markw4: 1 X SC 11.2896 MHz + 1 x AT 22.5792 MHz + 1 x AT 24.5760 MHz + 1 x AT 45.1584 MHz + 1 x SC 22.5792 MHz + 1 x SC 24.5760 MHz + 1 x TWTMC-DRIXO-F + 1 x TWTMC-PXO-F + 1 x TWTMC-DBM-F 22/24MHz to 45/49MHz + 2 x TWTMC-STS-SX + 1 x TWTMC-DRIXO-XFMR + 1 x TWTMC-EXO-F + 1 x TWTMC-STS-DX
- mksung: 1 x SC 22.5792 MHz + 1 x SC 24.5760 MHz + 2 x TWTMC-DRIXO + 2 x TWTMC-DRIXO-XFMR + 2 X TWTMC-DBM 22/24 MHz to 45/49 Mhz + 2 x TWTMC-DBM-XFMR + 1 x TWRPS-UGL + 1 x TWRPS-pp + 1 x TWTMC-STS-DX + 1 x TWTMC-STS-SX
- Sligolad: 1 X AT 5.6448 MHz + 1 X AT 11.2896 MHz + 1 offAT 22.5792 MHz + 1 off AT 24.5760 MHz + 1 off SC 5.6448 MHz + 1 off SC 6.1440 MHz + 1 off SC 11.2896 MHz + 1 off SC 12.2880 MHz + 2 off SC 22.5792 + 2 off SC 24.5760 + 2 off TWTMC-DRIXO + 2 off TWTMC-PXO + 4 off TWTMC-DBM + 1 off TWTMC-DRIXO-F + 1 off TWTMC-PXO-F + 1 off TWTMC-DBM-F + 4 off TWTMC-DRIXO-XFMR + 4 off TWTMC-PXO-XFMR + 4 off TWTMC-DBM-XFMR
- wlowes: 1 x SC 5.6448 MHz + 1 x TWTMC-DRIXO + 1 x TWTMC-DRIXO-XFMR
- Audio curiousity: 1 x SC 5.6448 MHz 3rd overtone 15 73,00 + TWTMC-DRIXO-F New Driscoll XO (without crystal) 120,00 + TWTMC-DBM-XFMR Frequency doubler transformers kit 21,00 + 1 x 11.2896 MHz TWTMC-PPG New Pierce entry with HC-49/U crystal 22,00 + 1 x 6.1440 MHz TWTMC-PPG New Pierce entry with HC-49/U crystal 22,00
- minionas: 2 × TWTMC-DRIXO-F + 2 × TWTMC-DBM-F + 2 × TWTMC-STS-SX + 1 × SC 5.6448 MHz + 1 × SC 6.1440 MHz
-tonerei : 2 x TWTMC-DRIXO-F + 1 x SC 22.5792 MHz + 1 off SC 24.5760 MHz
Cerole: 2 x TWTMC-DRIXO + 2 x TWTMC-DRIXO-XFMR + 2 x TWTMC-DBM + 1 x TWTMC-STS-SX + 1 x TWTMC-STS-DX
-Supersurfer:2x TWRPS-UGL-F Linear regulator 12V 70,00, 2x TWTMC-DRIXO-F New Driscoll XO (without crystal) 120,00, 2x TWTMC-DBM-F Frequency doubler 80,00, 2x TWTMC-STS-SX Sine to square converter (SX) 16,00, 2x TWTMC-STS-DX Sine to square converter (DX) 16,00
-Diyiggy : 1x SX ; 1x New Discroll ; 1 DRXO-trafo ; 1x new Regulator*
*: PP or linear acording the Voltage list needed. I wish to had a new entry Pierce raw board for the two AT-Cut I already own, but if the old Discroll pcbs I have are close performance from the new entry Pierce, it's ok and will avoid wastes & I will sleep better.
-gabor80: 2 x TWTMC-DRIXO + 2 x TWTMC-DRIXO-XFMR + 1 X TWTMC-DBM 6 MHz to 12 MHz + 1 X TWTMC-DBM 12 MHz to 24 MHz + 2 x TWTMC-DBM-XFMR + 2 x TWTMC-STS-SX
- woodturner-fran: 5 x TWTMC-DRIXO-F + 3 x SC 22.5792 MHz + 2 x SC 24.5760 MHz
-mbrennwa (please check if this is complete and makes sense for a IAN FiFoPi): 1 x SC 5.6448 MHz* + 1 x SC 6.144 MHz* + 4 x TWTMC-DBM-F* + 2 x TWTMC-DRIXO-F + 1 x TWTMC-STS-DX + 1 x TWTMC-STS-SX + Battery-PSU system (post 475)
[*only if this performs substantially better than higher-frequency crystals without frequency doublers; otherwise I'll take higher-frequency crystals without the frequency doublers]
- SimonJ - NOt sure what crystals yet and also not sure how many freq doublers you can have or how it works to it into the FiFoPi space? So for now...
1x TWTMC-STS-SX Sine to square converter (SX) 16,00
1x TWTMC-STS-DX Sine to square converter (DX) 16,00
2x crystals SC-cut, frequency TBC.
2x (may be more) TWTMC-DBM-F Frequency doubler 80,00
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-DBM-F "11 to 22"
1 x TWTMC-DBM-F "12 to 24"
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- nielsek: 2 x TWTMC-DRIXO-F + 2 x TWTMC-DBM-F + SC 5.6448 + SC 12.2880 + TWTMC-STS-SX + TWTMC-STS-DX + TWRPS-UGL-F or Battery-PSU
- CV placeholder - number of crystals and boards TBD
- fralippo: 1 x TWTMC-DRIXO-XFMR + 1 x TWRPS-UGL + 2 x TWTMC-STS-SX
- Emi90: 2 x TWRPS-UGL-F, 2 x TWTMC-DRIXO-F Driscoll XO, 4 x TWTMC-DBM, 2 x TWTMC-STS-SX, 2 x TWTMC-STS-DX
-clsidxxl:1 x SC 5.6448 MHz+ 1 x SC 6.144 MHz +2 TWTMC-DBM-F+2xTWTMC-DRIXO-F or 2xTWTMC-EXO-F+2xTWTMC-STS-SX +Battery-PSU system or TWRPS-UGL-F
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
Interests list:
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
-alecm: 1 x SC 11.2896 + 1 x SC 12.2880 MHz + 2 x TWTMC-EXO-F, TWRPS-UGL-F, TWTMC-STS-SX(FifoPi) + TWTMC-STS-DX(FifoPi), DRIXO-EXO-PXO
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
Interests list:
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- rowli: 1 x SC 5.6448 MHz, 1 x SC 6.1440 MHz, 2 x TWTMC-DRIXO-F, 4 x TWTMC-DBM-F, 2 x TWTMC-STS-SX, 1 x TWRPS-UGL-F
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
Interests list:
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
1 x SC 5.6448 MHz + 1 x SC 6.144 MHz + 2 x TWTMC-DRIXO + 2 x TWTMC-EXO + 2 x TWTMC-DRIXO-XFMR + 2 x TWTMC-EXO-XFMR + 1 x TWRPS-UGL + 1 x TWRPS-pp + 1 x SC 22.5792 MHz
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
Interests list:
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
1 x TWTMC-DRIXO-F + 1 x TWTMC-DRIXO + 2 x TWTMC-EXO + 2 x TWTMC-DBM + 2 x TWRPS-UGL + 1 x SC 22.5792 MHz + 1 off SC 24.5760 MHz
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
I am sorry to only just be discovering this group buy so I am finding it a bit confusing.
Might I suggest a spreadsheet ordering system similar to Ian in Canada. Total pieces could be easily tracked and all necessary items could be grouped based on ones needs, plus you would have an easy reference with total for each persons order come payment and shipping time. Ian might even help with info to set up same as so many of us seem like we will be populating his boards.
In my case I am building two of Ians older Mc Fifo each with dual clock boards. I would like the best available solution, but am not sure what that is. I need to be able to support up to 192K and up to DSD 128. Any guidance would be greatly appreciated.
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
- Canvas: 1 x SC 11.2896 MHz, 1 x SC 12.2880 MHz, 1 x TWTMC-DRIXO, 1 x TWTMC-EXO, 2 x TWTMC-DRIXO-XFMR, 2 x TWTMC-EXO-XFMR, 2 x TWTMC-DBM, 2 x TWTMC-DBM-XFMR, 2 x TWTMC-STS-SX, 1 x TWTMC-STS-DX
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
@stephen1212b: Hi Stephen ... I cannot guide you as to what would be the best solution for your purposes but the main thread for these oscillators is here (you may know this, of course):
The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
If you look at #2257 this is the starting post ("announcement") for the new GB. If you go back some pages from there you can find measurements of the performance of a couple of the new series of oscillators and a bit of description. The actual circuits have not yet been revealed as Andrea & Co. are still fine tuning them.
Jesper
Jesper
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
- koala887: 1x SC 5.6448 MHz, 1x SC 6.1440 MHz, 1x SC 11.2896 MHz, 1x SC 12.2880 MHz, 1x SC 22.5792 MHz, 1x SC 24.5760 MHz, 4x TWTMC-DRIXO, 4x TWTMC-DRIXO-XFMR, 2x TWTMC-DBM, 2x TWTMC-DBM-XFMR, 2x TWTMC-STS-SX
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
As for the previous GBs, I will provide a spreadsheet order form as soon as all boards have been tested and tuned.
About Ian's boards frequency (DualXO, McDualXO, FifoPi), please ask him.
Update to Markw4 request
-Markw4: 1 x SC 5.6448 MHz + 1 X SC 11.2896 MHz + 1 x AT 22.5792 MHz + 1 x AT 24.5760 MHz + 1 x AT 45.1584 MHz + 1 x SC 22.5792 MHz + 1 x SC 24.5760 MHz + 1 x TWTMC-DRIXO-F + 1 x TWTMC-PXO-F + 1 x TWTMC-DBM-F 22/24MHz to 45/49MHz + 2 x TWTMC-STS-SX + 1 x TWTMC-DRIXO-XFMR + 1 x TWTMC-EXO-F + 1 x TWTMC-STS-DX
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
- Blitz: TWTMC-DRIXO-F + TWTMC-EXO-F +TWTMC-DRIXO-XFMR +TWTMC-EXO-XFMR + SC 22.5792 MHz +SC 24.5760 MHz +TWTMC-STS-SX +TWTMC-STS-DX
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
- spm TWRPS-pp x2 TWRPS-UGL x2, TWTMC-DRIXO x2, TWTMC-EXO x 2,TWTMC-DBM x 2, TWTMC-DRIXO-XFMR x 2, TWTMC-EXO-XFMR x 2, TWTMC-DBM-XFMR x 2
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
- Rrbs : 2x TWTMC-DRIXO-F , 1x TWTMC-STS-SX ,1x TWTMC-STS-DX ,1 x SC 5.6448 MHz , 1 x SC 6.144 MHz , 4 x TWTMC-DBM-F
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
-Sebbyp: 1x SC 5.6448 MHz 3rd overtone 15 73,00 1x SC 6.1440 MHz 3rd overtone 15 73,00 1x SC 22.5792 MHz 3rd overtone 10 41,00 1x SC 24.5760 MHz 3rd overtone 10 41,00 4x TWTMC-DRIXO-F New Driscoll XO (without crystal) 120,00 2x TWTMC-DBM-F Frequency doubler 80,00 2x TWTMC-STS-SX Sine to square converter (SX) 16,00 2x TWTMC-STS-DX Sine to square converter (DX) 16,00
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
Some questions:
- When will we see more information about the performance of high-frequency crystals vs. low-frequency crystals with frequency doublers?
- When will we see information about the new power supply?
- When is the deadline to commit for the group buy?
A pair of weeks to publish all the measurements.
Then I'll publish all the BOMs and the Order Form spreadsheet.
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
- Aihorn: 1 x SC 5.6448 MHz + 1 x SC 24.5760 MHz + 2 x TWTMC-DRIXO + 2 x TWTMC-DRIXO-XFMR + 1 x TWTMC-STS-SX + 1 x TWTMC-STS-DX + 1 x TWTMC-D&D
- G600
1 x SC 11.2896 MHz
1 x SC 12.2880 MHz
2 x TWTMC-DRIXO-F
1 x TWTMC-STS-DX
1 x TWTMC-STS-SX
- pistollero:
- randytsuch
- Group Buys
- The Well Tempered Master Clock - Group buy
