Andrea, I'm out. Can you take me off the list please?
Ok, done.
In order to meet the MOQ for each frequency, I will get some crystals in excess.
If you are interested, please update your order form. Follow the list of the available Crystal:
AT-Cut 6.1440 MHz fundamental 2 pcs
AT-Cut 11.2896 MHz fundamental 5 pcs
AT-Cut 12.2880 MHz fundamental 4 pcs
AT-Cut 25.0000 MHz fundamental 4 pcs
AT-Cut 45.1584 MHz 3rd overtone 5 pcs
AT-Cut 49.1520 MHz 3rd overtone 5 pcs
Hi, if you have excess crystals for the following frequencies:
...I would be glad to have them.
Yes, they are available.
If you are interested, please download the order form in post #761, fill it and send it me back.
Update
The payment requests have been sent to all the members.
As soon as I received all payments I will place the new order to Laptech.
Hi andrea,
Payment sent. BTW, the board of Driscoll and oven will be on next GB? I didn't see them on the order form.
Hi andrea,
Yes, I have to get SC-cut crystals firstly, without them I cannot test the new Driscoll oscillator board.
Hi Andrea,
Payment sent. Could you add to my order 2 TWCMC-C XO boards?
Thanks,
Alex
OK, I add 2 XO boards to your order.
Hi Andrea,
Have you tried the PO38072 1:2 clock buffer as sine-to-square wave converter? I found it has excellent performance. Could be a better alternative to 74hc04 logic.
Hi Andrea,
I cannot find anything on the web about the PO38072, can you provide a link?
I suspect it's the potato semi: http://www.potatosemi.com/potatosemiweb/datasheet/PO74G38072A.pdf
Room treatments for headphone users
Sorry, the correct name is PO74G38072A. Product page is here. If you like I can send you a sample.
Hi ..
@jborden:
Might you also have experience with the jitter level in their other IC's - like e.g. their PO74G74A flip-flops?
Jesper
@jborden:
The pot semi clock chips have the lowest pin to pin skew (jitter) I've found.
Jesper
Reminder
I would finalize the order to Laptech, so I ask the members who have not yet payed, please do it as soon as possible.
Thank you
Andrea
Thank you
Andrea
Last reminder
Miklos, Gunders,
you have a payment request for the Laptech GB.
Please, let me know if you will pay for the crystals. Otherwise I should cancel your orders to finalize my order to Laptech.
Thank you
Andrea
Miklos, Gunders,
Thank you
Andrea
Hi ..
@jborden:
Jesper
I've used them because of their reputation for low noise low jitter but don't have the equipment to measure levels that low
Jon
- Digital Line Level
- The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
