Nice simple head-phone amp.
I have built a beefier version of this amp for driving loudspeakers and testing positive current output, as documented in this thread:
http://www.diyaudio.com/forums/pass-labs/301491-pcf-without-global-nfb.html
Your small mp3-clip of music sounds very clear, transparent and nice through my speakers to.
Johannes.
Johannes.
The sound from both amp sound great. So clean and clear. A vocal track would be nice.
Can the amp in the first post with 2 transistors ok as a preamp?
Thanks for posting
Yes you can use as preamp but care is needed with clean PSU to avoid hum as there is no PSRR here. Or use large rechargeable batteries. A cap multiplier and regulator should be ok.
Johannes.
Nice power amp! Is the PCF needed? I have no feedback, and wonder what happens with PCF on my headamp.
Pocket Class A Headamp GB
I am starting a GB for the little Pocket Class A SE Headamp over in this thread:
http://www.diyaudio.com/forums/head...lass-headamp-without-heat-24.html#post4965668
PCB:
![591358d1484063759-bf862-based-se-class-headamp-without-heat-pocket-class-bf862-zvn5306-ha-v1-new-oscons.jpg](https://www.diyaudio.com/forums/attachments/headphone-systems/591358d1484063759-bf862-based-se-class-headamp-without-heat-pocket-class-bf862-zvn5306-ha-v1-new-oscons.jpg)
PCB:
![594826d1485450543-bf862-based-se-class-headamp-without-heat-pocket-class-gb-layout.png](https://www.diyaudio.com/forums/attachments/headphone-systems/594826d1485450543-bf862-based-se-class-headamp-without-heat-pocket-class-gb-layout.png)
Just a reminder if anyone here has an interest in the GB, we are at 36 boards now and it will be closing in a few days.
http://www.diyaudio.com/forums/group-buys/302859-xrk971-pocket-class-headamp-gb-3.html
Pocket Class A Headamp GB List
xrk971 - 2 boards
pcgab - 2 boards
zman01 - 2 boards
stellarelephant - 2 boards
samoloko - 1 pcb
lui04 - 2 boards
Morde - 2 board
cyteen - 2 boards
funch - 2 boards
syyma - 2 boards
av-trouvaille - 2 boards
Mituisho - 2 boards
bogde - 2 boards
faltinsen - 2 boards
vanofmonks - 1 board
M_Balou - 2 boards
dwpeterson - 1 board
agdr - 1 board
walangalam - 2 boards
gwrskien - 2 boards
Zvn 4306 overheating
I built the circuit according to the schematic in the first poat. Manage to trim the voltage at source of zvn at 6.5v. Very nice sound but zvn is too hot to touch a few minutes after power up.
input voltage is 16 v .
ZV bought from element14
Any pointers to solve the problem?
Sure it is.... zvn is too hot to touch...
It is dissipating about 0.5W ((6.5/120)*9.5) so some sort of heatsink is needed.
You are using TO92 part and it makes heatsinking a bit more problematic. If you were using an SMD part that would allow for easier heatsinking (by using the large copper area on the PCB).
Nice work. Thanks for trying it.
Use a TO-92 heatsink or use SOT-223 and large copper plane for heatsink.
SOT-223 actually easier to solder than TO-92.
![F7124320-01.jpg](https://uk.rs-online.com/largeimages/F7124320-01.jpg)
Here is another 2-transistor amp, this time JFET-BJT ouput. Aksa designed this one to have an adjustable harmonic profile via R4 as a "niceness" knob using a pot.
Proof of concept with 2SK170BL instead of BF862 on solderless BB works well, now off to a hand drawn PCB.
PCB with built in cap Mx and powered with a DC-DC converter to get 20v rail from 5v to 24v input:
![595829d1485850200-mosfet-source-follower-headamp-jfet-bjt-amp-cap-mx-01.jpg](https://www.diyaudio.com/forums/attachments/solid-state/595829d1485850200-mosfet-source-follower-headamp-jfet-bjt-amp-cap-mx-01.jpg)
Hi X,
I have 2sk170 and bd140. Can you post the schematic ?
Here's the schematic - thanks to Aksa for the simulation and design!
![592252d1484479361-mosfet-source-follower-headamp-cfp18vhpa1.gif](https://www.diyaudio.com/forums/attachments/solid-state/592252d1484479361-mosfet-source-follower-headamp-cfp18vhpa1.gif)
More info in this thread:
http://www.diyaudio.com/forums/solid-state/301164-mosfet-source-follower-headamp-30.html
Yes, I dropped in a 2SK170BL and it worked - the Idss of the 2SK170BL should work nicely with a 7mA requirement. If you get a chance, buy a roll of BF862's they are very inexpensive and nice devices to work with. About $0.40ea from Mouser/Digikey and half that from eBay/China - don't worry, no one is bothering to fake a 40cent SOT23 (yet).
Effect of niceness knob (degeneration resistor) on JFET-BJT headamp.
http://www.diyaudio.com/forums/solid-state/301164-mosfet-source-follower-headamp-33.html#post4971963
- The Sound of Two Transistors Clapping
