The simplistic Salas low voltage shunt regulator
I would start with V1.1 Mosfet output symmetrical VCC+ VCC-, set at 100mA fed from existing bridge and 2200uF filter caps for the 5532s in the analogue output. There are many chips with 3.3V needs. I would substitute the A+3.3 and D+3.3 regulated feeds for V1.1 BJT with 10.000uF electrolytic filter cap. You should measure the current at A,D, feeds and set CCS accordingly. See in the SSLV1.1 build thread for guide, other builder's examples etc.
It was one rather basic variation for small voltage margins that I designed for powering DHT heaters on a request by Dutch member Disco. See the post number I mentioned. It has been shown on the #26 preamp thread too on the actual preamp along with double mono original SHV with BJT Vref. Its sometime back.
