The simplistic Salas low voltage shunt regulator
Is really there a 100R in the tried circuit? Isn't that a notional initial figure and that one got to be the 16R dummy load in practice? If its really there then its 116R shooting up the output and squeezing the Mosfet. There will simply be no voltage margin for what 300mA can do with that value so to be reachable. Am I missing something?
This is the circuit that I think we should be building!
Yes, it looks like it is working well now. Need to make R1=16.5 to 17R, to get about 0.29A. Can add 1.8R or 2R resistor in series with the 15R.
BTW, the IRF9610 will be dissipating 2 or 3W - just wanted to check you have a little heatsink on it. Run it for an hour, check it's not too hot to touch. THen it will be ready to test on the 6922 heater.
300mA through 2r0 is only 180mW. You can use a 500mW or 600mW 2r2 resistor.
Then trim the 2r2 to set the precise current through your heater filament.
2r2 // 22r = 2r0
2r2 // 10r ~ 1r8
You can try trimmer values between 5r6 and 1k till you are happy.
You say you got nearly 5V across R1. If 0.3A passes that is 1.5W. 2W total will work hot only for quick enough test, and you will have to use 5W in the long run. Also keep legs a bit high so the resistor(s) will not be touching the board.
