The simplistic Salas low voltage shunt regulator
Back to other diodes but only get 16.09V....
It is possible that the lowered reading is also due to oscillations - you moved the current source away from the supply capacitors. I think you need to find if you have that oscillaion problem, or not. Adding extra capacitance is one thing that might help.
Also, increasing the IRF9610 gate resistor from 220R to 1K may help, if you have no scope to debug it.
Guys, sorry for intervening, wasn't online much today to follow you anyway, but looking at the progress, a question came to my mind. Since you are trying to separate the constant current source from the initial reg design example and to current feed a dummy load and eventually a heater, shouldn't there be a test with a stabilizing capacitance across its output with some ESR damping (i.e. an output lytic) and/or a slower Mosfet even?
Yes, I agree, connecting 47uF or 100uF across the dummy load is worth trying.
Please check the connexion of the 1000uF. It should be from the DC supply [+ pin] positive to ground [- pin]. mounted on short wires, and located near the IRF9610
You are right, there should be no lumped inductance in the input or output loop of a fast Mosfet CCS. The input cap ought to decouple very near. I would also say that the 47-100uF test across the load maybe better be on perf board near the 9610 than on the load itself.
It's correct?
