Yes, you can evaluate subjectively in all. But the film cap smallest acceptable value depends on how much R is in the Vref. If its only leds and very little or no R it can be small. Like in DCB1. In others higher Vout with many leds and/or enough R it can be 10uF even. In general, telling me how is the Vref made, I can reply you least film cap value acceptable.
Wich values film cap will be acceptable for:
+5.5V reg. Vref made 2 Leds 1.8V + 1 trimmer 200R
+-15V reg. Vref made only 8 Leds 1.8V without trimmer/diodes
+-24V reg. Vrf made only with 13 Leds without trimmer/diodes
For +45V I have VRef 4k7+5ktrimmer instead the leds, if I change the resistor for Leds, how many Leds 1.8V I have to use, also here can I use the film cap, wich value?
Had a look. Fortunately in all those 3 cases, because very little or no R element is used, the loop gain will not suffer in the very low frequencies even with 1uF.
Of course the noise filtering is stronger the more uF and maybe it will be interesting to listen for a 10uF also in the many leds 24V case and evaluate if it is beneficiary subjectively. It may very well not be discriminating for any essential noise and the more compact 1uF win in all those 3 situations.
I am afraid that so many Leds for a 45V may create more noise than the resistor+trimmer. But if you want to experiment it will be interesting, those are different Vrefs still. You will need 10uF in both cases. A couple of // compact radial Arcotronics or Rifa, Wima, with a Vishay MKP1837 bypass should be faster than expensive designer caps.
It's not me, Merlin asked.
A real PITA (not your pita!) to select so many leds, maybe smd type, for me!
Perfect I will try with these 1uF/630VDC Mundorf MCap ZN tin foil polypropylene & Auricap 1uF/450VDC metallized poplypropylene
Just for fun, pic reg V1.0 with remote sensing before upgrading the VRef cap to film.
Hi Salas
I had not the oportunity to follow all the las posts but I seem to understand that a led + film cap vref should be more silent than the resistor + EL on the V1.
Is this correct ?
Is this correct ?
Film cap VRef
Photo 1uF 630VDC film cap instead the 100uF/25V lytic in VRef
Now I'm waiting stabilization Vout with BII as load to setup the +5.5VDC & after the listen test.
Hi Salas
Is this correct ?
Depends on the number of leds, the value of the resistor, the filter capacitor's value. The leds are stiffer and have different dynamic impedance. And there is subjective difference that you got to experience and evaluate.
@Salas
Listened with 1uF VRef, mine subjective opinion is that I prefer the 100uF lytic, seems (like always I change lytics vs films) films are more clear or without bass so the sound loss deep like more flat.
I have several possibilities:
-Add more caps to 1uF, I have Monacor metallized polypropylene 3.9uF & 8.2uF both 250VDC
-Substitute for one 4.7uF Mcap tin foil polypropylene
-Substitute for one 10uF 425VDC TRT Wonder Signature metallized poplypropylene
Try your other caps too. Bigger values. Lytics are more Hi-Fi in my opinion in that position. Bigger but more color. Depends on the loudspeakers too. Maybe for you a lytic and very small bypass in the end. Takes experiments.
I used 10uF // 10nF, result: films in that position aren't for me, come back to Elna Silmic II & I will try bypassing with 10nF.
Whatever floats better in the system context. In my experience the resolution and projection does noticeably better with MKPs there and so said everybody who substituted in the DCB1. No flattness, to the contrary. Same with 1.2 regs on the phono. Then again this is feeding digital circuits here and maybe works differently. Do you use any subwoofer suplementing the Wilson Cub pair by the way? I have auditioned that speaker a few times and seemed clean but ovedamped to me. Can be fighting with even cleaner tone?
- Power Supplies
- The simplistic Salas low voltage shunt regulator
