Is there a high voltage v1? I might have seen it before. I did a search but could not find it. I am thinking about replacing the one in my tube preamp.
http://www.diyaudio.com/forums/tubes-valves/134801-simplistic-mosfet-hv-shunt-regs.html
Most series regulators have inductive outputs. So film capacitors, or even low ESR electrolytic capacitors can not be used at the output.
It's virtually impossible for a regulator not to behave inductively as the frequency goes up. Yes, one has to be careful with the output capacitor. I would not go as far as to say, "cannot be use."
What about v1 and v2? Are they inductive at the outputs?
All of them are. It depends how fast, as a function of frequency, the impedance goes up. That will be how they differ.
The recommended value of 470uF at the output suggests a reasonably low ESR. If it does not resonant, it means at least the output is far less inductive than most series regulators. The question is, how low the ESR can the regulator tolerate? Would it oscillate if you put a film capacitor there?
As far as v2 goes, I recommended as small a value as possible for the output capacitor. It's difficult to predict how low the ESR should be. Everyone may build the regulator differently, some p2p, others with their own pcb, resulting in different inductive behaviour for each and hard to predict the interaction with the cap ESR.
I know that the regulator provides a very low impedance at the output so a film capacitor may not be necessary. But that may be in theory only. Above some point, e.g. 200kHz, the impedance of the regulator has to rise again. This could make it inductive (but not necessarily so).
In my case the output capacitor is not intended to do this. In v2 it is for stability.
Modern opamps often work till 10MHz and above.
Look at the plot of gain vs. frequency. There are no miracles.
So local film capacitor bypass is generally recommended. In practice, I (subjectively) found such bypassing causes ringings that destroy the integrity of sound. RF can get into the circuit in many ways. Without bypassing, there is another set of problems. It has never been easy to work with opamps due to the wire resistance, wire inductance and parasitic capacitance, especially with some inductive outputs from voltage regulators.
This is true of any regulator, no matter whether it's bypassed with a cap or not.
I think the real question is how much we can get away with, in a real circuit.
There is the simplistic HV, but that one is a different, not strictly V1 style, whimsical circuit, mostly anecdotally documented. People like it very much for some reason, but its not technically that serious or reliable, beyond what is tested to work with till now, by some members later and me initially.
Here are the pictures.
I prefer using individual heatsink for individual MOSFET as a habbit, as I am worried about the high capacitance between the MOSFET and heatsink (think about how a capacitor is made from). Sharing a heatsink between MOSFETs means connecting them with a capacitor. The MOSFET used here are large TO247 type. Fortunately, the drains would be connected so there would be no issue. This is not the same with v2. Nevertheless, I am lazy. I don't want to do extra drilling so I got these cheap screw-on heatsinks. They don't look like 6 degree / C thermal rating they have on the badge.
I also add in the thermal pad to isolate the drain from the heatsink, not necessary but in some cases may be helpful.
Provided that the thermal pad adds 2 degree / C making it 8 degree C, consider that I will use around 350mA on 15VDC rails the power disappation may be up to 6W per MOSFET. So the maximum temporature would be up to 50 degree higher than room temporature, let us say 80 degree at maximum. Since the MOSFET can operate up to 150 degree (bad performance though), I guess it would be fine. In real life, the figure would be a bit lower.
Top view:
Comparing to the PCB design:
Bottom View:
Today I replaced the trimpot with 220R (+) and 180R (-). The stablized voltages are now +13.07VDC and -13.17VDC. I can't be more happier with that. Of course, when the new batch of 2SK170 arrives I will replace the njfet.
It still took some time to stablize the negative voltage so the problem is not the trimpot.
Finally, a picture showing my latest work: I removed the "input" and output capacitors from the board. Solder some wires on their positions, and solder the capacitors on the stand-out wires. This got it ready to do capacitor tests, as it is much easier to solder and desolder them without disconnecting the boards. They may look like antenas, but they sound OK.
I have already got some very interesting test results. But I won't post them until I finish all the tests.
Very orderly work, good base for clean experiments. When you will change the NJFET see to find one with about the same IDSS. Some difference leads to another Vset resistor value for same Vout of course. If it will still take some time to settle, means it is something (Tc and time related most probably, not terrible) with the negative side. Not in -Vref only by definition. Is it about 0.6V the total slide? That BC560C is nearer than the 550C, talking buffer part. Could be more Tc susceptible for instance. No big deal in my book anyway, if it is not associated with some instabillity. Without instruments, you would hear periodic whistle and buzz if it was something serious. You did well to isolate, once, early in the phono thread someone pushed together the individual sinks, got a zap and a bang, but the IRFPs did not blow. Tough fellows. Also for getting a bit hot, they aren't the ones who gonna riot sooner than others. Now you tune your sound, good part of the job. It is nice that someone is going to listen a lot to versions in a big system, tune 'em, recommend uses etc. Good info. Cheers.
v2 is more of a topology. You can find the topology in post 1168
link to post 1168
Some resistors and the zeners have to be changed for your needs (voltage out, current). Post what you intend to power with it and we can help you with that.
Checked it.
I'm evaluating shunt regulators circuits for a low-wattage class A amplifier dedicated to HF. The voltage requirement is 17V, amperage around 1A.
Which values would you suggest for my needs?
Very clean job, I like it
Logic level mosfets may work. For v1, something like this
NDP6020P Datasheet pdf - P-Channel Logic Level Enhancement Mode Field Effect Transistor - Fairchild Semiconductor
For v2, many choices of n-channel logic level mosfets.
Thanks for the input, and Salas too.
I think I will build a BJT version first as I have some BD140s on hand, then convert it to mosfet at a later date.
Checked it.
If you use 1N4738A for D1 and D2 you get around 16.7V output. You need to adjust R2 to get the current up to the value you want. That needs to be done experimentally. You can use a 10K trimmer for R2, and start at about 2K. If you're running 500uA through R2 then somewhere between 8k and 10k will give you the 1.xA current limit that you want.
It's not exactly a beginner's project, you need to be comfortable with applying Ohm's law left, right, and center. (I'm not kidding. )
It'd be best to choose a target schematic, either v1, or v1.1, or v2. I'd recommend v1.1 or v1, to get your feet wet. Then choose your target voltage and current. Then, if you really want to use the BD140, someone needs to make sure it works in that schematic.
Sure, I'm looking to build something close to V1, with up to 100mA total current. Load current is around 40mA. At worst it may oscillate, at which point I'll have to do something to decrease the gain of the circuit.
The trouble with getting a logic level mosfet is getting it in low quantities without paying ridiculous postage. I'll order some next time I need a batch of components from Farnell. Famous last words, but I can't see why the BD140 wouldn't work. There are plenty of shunt schematics out there, many of which use a PNP in a similar configuration. I'll report back.
- Power Supplies
- The simplistic Salas low voltage shunt regulator
