@ikoflexer
it is well known 24/192 DAC from Ebay. I am using it to experiment. This "el-cheapo" is not bad, considering price & after some modifications, of course.
Bad thing is CS4397 get easily burned, but have several chips in my spare parts box. Replacement is 3-minute job.
Shematic is here: http://www.shrani.si/?1X/x5/9esiKsT/dac1.jpg
http://www.shrani.si/?3F/9O/2G6LodNt/boardshema.jpg
@AndrewT
I am better with soldering iron as with computer drawings 😀
I am old fart with shaking arms, my eyes having problems with SMD parts, but I can still read my multimeter with 2,5 cm big digits 😉
Shunt reg at 5V is only for receiver & DAC chip. Load is going from 56.12 mA and 56.16 mA. For me this is constant load.
Output from DAC is going through 3rd order filter to analog/buffer JFET stage, very similar to Borbely's EB604/410 All-Jfet Line Amp and powered from 24V.
Not enough time to finish my Aikido line stage
@anatech
As far as I understand Teddy's Super reg, first stage is LP filter, with pass transistor. First transistor have similar function as first MOSFET in Salas shunt reg.
@AndrewT
@anatech
Hi Salas,
I don't know about being faster is an answer or not. Normally a bypass capacitor satisfies those needs well enough. Of course, a bypass capacitor may cause trouble depending on the characteristics of a shunt. Noise in the shunt may translate into high current pulses as the capacitor(s) attempt to maintain the voltage across their contacts.
If you have digital and analog sections on the same supply, it needs to be a stiff as possible, hence the larger values of bypass capacitors, to a reasonable limit of course! The demands on a purely analog section should be a great deal less, but you still have to deal with current demands across the entire audio range, right on up to the sampling frequency. That can be pretty high. Again, you are looking for a voltage source with infinite current available instantly. That leaves you with a choice between using capacitors or a pass element capable of video frequencies. The filter capacitor route may generate less noise in a pass configuration. It's cheaper too!
Personally, good supplies can be constructed either way. You have to imagine the supply from the load's point of view. It doesn't care how the power gets there, it only cares that it is stable and can supply small current pulses as needed. I would guess that a current output DAC will draw less. If you use a voltage output DAC and install small capacitors to ground at the output, you're going to draw some peaks of current. So I would say that the filter design may have more influence than the power supply on the sound quality. That's assuming that the power supply is of good design either way (series or shunt).
-Chris
-Chris
Hi stormsonic,
I do think he touched on a valid problem though. That is the inability, or reduced ability, for normal three terminal regulators to block the higher frequency noise. Mind you, if you don't have to loss some voltage, an L-C filter combination before the regulator might fix that. If you do have to drop some voltage, I'd be using a switching regulator first. Then L-C filters can be extremely effective at removing the high frequency components. Switching regulators switch from about 200 KHz to 1 MHz and beyond these days, and they are not exotic parts.
More than one way to skin a cat, and the Teddy Super reg. will work. If I'm going to go to all the trouble of building something, I want better performance.
-Chris
True, but my point is that there is no correction for IR losses at all. I wouldn't call it an effective voltage regulator.As far as I understand Teddy's Super reg, first stage is LP filter, with pass transistor. First transistor have similar function as first MOSFET in Salas shunt reg.
-Chris
Just a quick comparison between v1 and v2...used on a non oversampling DAC, the v2 sounded consistently cleaner with a darker background. The same characteristic was also noticed when used on the Salas RIAA.
Hi Tham,
Quick question for you.
When an A/D circuit is changed from an oversampling type, to a non-oversampling type, do you also correct the filter section back to a 7th order type? Either that, or is the DSP or digital filter changed?
I only ask because I figured that since you are experimenting with these, you might know the answer.
One thing I do know is that if you drop the sampling rate, you must also change the anti-aliasing filter in the following analog section. Otherwise you will have quite a bit of ultrasonic noise passing through. Don't expect to hear it.
-Chris
-Chris
Hi Chris,
It is a commercial kit that I built upon. No idea what the design topology is though.
Hi Iko,
It is what the hobby is about...no venture no gain 🙂 . Never have any experience with other super regulators, but both v1 and v2 imho are excellent regulators on their own.
Hi Iko,
Tham, I've tried quite a few regulators myself, including some Jung variations. Maybe naive, but I was more impressed with salas v1. I cannot recommend v2 because it would be a biased recommendation; people should make their own mind about that.
Chris, hello neighbour! Nice to see you active in this thread.
Edit: typo
Edit: typo
Tham said:Just a quick comparison between v1 and v2...used on a non oversampling DAC, the v2 sounded consistently cleaner with a darker background. The same characteristic was also noticed when used on the Salas RIAA.
ikoflexer said:tham, thank you for taking the time to build and test v2. You're a brave man 🙂
ikoflexer said:Tham, I've tried quite a few regulators myself, including some Jung variations. Maybe naive, but I was more impressed with salas v1. I cannot recommend v2 because it would be a biased recommendation; people should make their own mind about that.
Non the less it has been proven that it works as intended Iko, and we should establish a pcb design for V2 and recommend it as the advanced bandwidth version for people to try as a possible upgrade.
Tham, my higher current v2 +/- is almost finished.
I got sidetracked with a dht headphone amp design and building a high voltage v2n (v2 with n-channel mosfets) for it. That is almost finished too... if I could only work on one project at a time... 😀
salas, if anyone wants to do the pcb layout, I have nothing against it. As it is, I will not have time to do it right now, plus, my layouts you've seen... not exactly works of art.
so, go for it
so, go for it
Need to build a regulator for my T amp and hope to use a v2. Do I need a higher current version for this application?
what's the speaker current draw?ikoflexer said:What's the t-amp current draw? Does it need both positive and negative?
some more things to V1:
decreased output capacitor value to 47uF, better highs. Experimented with Q5 (under 3 x LED string) and like there 2SK170BL or 2SK117GR or 2SK363 (with higher Idss) or BF245B.
I do not like there 2N3819.
Which post is final shematic of V2 ?
Post #578. You'll need to change the Vref zeners for your voltage, and the series resistor (R9) for the quiescent current. If you tell me what's your Vout and the idle current you want I can post a schematic with adjusted component values for you to try. The two bjt may need a small cap each to stabilize it (18-200pF range).
Iko, not sure of the T amp current draw but read in another forum that TA2020 can draw momentarily up to 3.5A.
Tham said:Iko, not sure of the T amp current draw but read in another forum that TA2020 can draw momentarily up to 3.5A.
That might be wrong though. The ta2020 datasheet rates 25W max into 4 ohms. Maybe 2.5A max draw? Maybe you could measure the current draw at your normal listening level? Would you like to have an idle current of 3A through the shunt mosfet, with 0A load? Sounds scary 🙂
- Power Supplies
- The simplistic Salas low voltage shunt regulator
