The Phonoclone and VSPS PCB Help Desk
I have a vsps. It feeds my preamplifier that has an input transformer. Can I omit the output capacitor on my vsps knowing that an input transformer is in place?
Mike, I think Bas meant that the transformer is on the input of the preamp. Not the input of the opamp.
Still, I do not know if it would be a good idea to expose the transformer to the possibility of core saturation because of DC.
Don't allow any DC offset current to pass into the signal transformer.
VSPS 51g and Emerald photos
Proto boards arrived today. I like the basic green mask, it shows off the trace work nicely.
Hi. A question has arisen. I see the S-reg circuit of the CrystalFET and I realize that it has a CRC filter and Q7-Q8 is MOSFET, that the VSPS 400 does not have it.
Would it improve my future VSPS400 something if I make these modifications? or is it better to leave the circuit as designed?
Greetings.
@ALPUY
The story there is the extra capacitor lowers the ripple but it is not needed with the VSPS/Phonoclone since the PSRR of the op amps is already high. The CrytalFET has a PSRR of negative 20 dB so I had to pull out all the stops so to speak.
@Lohengrimas
I'm no longer so enamored with the GC to be able work up the enthusiasm needed to develop that, though I do agree a one box phono amplifier as an idea has a certain merit.
OpAmps for the VSPS 200/400.
The OPA 134 works perfectly in these circuits. The Analog Device's AD797 however does'nt - too my surprise I might add. The sound being highly distorted and with no signal "motorboating" is clearly audible.
Any suggestions would be appreciated as the AD's are rather costly.
