From back to front:
Array of blue LEDs ---> diffusor made of etched glass or rough-sanded perspex/plexiglass ---> wire screen ---> chrome plated exhaust port with desired nozzle shape or rolled lip shape
The trick is to black out a portion of the diffusor with several coats of black nail polish, so light is emitted only from the clear, non-blacked zones. If the port is circular and the diffusor is circular, you could black out the center of the diffusor, leaving only a thin annulus of clear around the perimeter. This will emit a soft glow around the circumference of the port but no light from the center. Of course, other shapes and other blackout patterns on the diffusor would create different lighting effects. Bulls-eye might be particularly amusing.
Optional LED drive circuitry could make 70% of the LED array glow at constant brightness, while the other 30% does a "breathing" effect, or a "twinkling" effect, or a random trianglewave effect, to emulate exhaust flashes from a Rolls Royce Merlin V-12 on a Spitfire, or to suggest flickering flames from a bonfire, or a fission encabulator engine running dangerously close to self-detonation.
@stajo Lol dude, that kind of suggestion is a perfect 7/10 trap... kinda like a cmoy headphone amp in a mint tin or a coffee can forge or a simple rocket stove that morphed into a high flow, folded flue wood stove 🤣
Adding it to the list anyway because I never learn.
@Mark Johnson Ding ding ding... I'm clearing off the welding table to start messing with your ideas. Thank you
A small step for an elk, but a giant leap for a guy from Vienna... my first aurora borealis - in Vienna, it's crazy... 😍
Similar here im France. I was sitting on a balcony and then looked north...A small step for an elk, but a giant leap for a guy from Vienna... my first aurora borealis - in Vienna, it's crazy... 😍
Nice with some northern lights. We had it in Stockholm this year also. Unusual. Well The Big Elk Walk is up on its last leg, the live broadcast from the 30 PTC cameras ends tomorrow at 24.00. But it is already a new record, the cameras has caught 80 elks up till now swimming the river. Earlyer record was in 2022 with 67. It was last weeks push of warm weather that made them line up I beleave. Right now its around zero degrees up there and no elks in the cameralenses, but beautiful pictures of a mirror blank river floating.
It is apparently the most powerful solar storm in 20 years going on. Might even effect electronics, knock out internet worst case.
We are in the shadow of the halo they show on the earth map. So no is the answer unfortunately. Also, too much city light.
Edit: Just went outside at 10 pm and there’s way too much light pollutio.
- The Pass Pub: The High-End Off Topic Thread
