Jeff buy a transport and play your cds its more fun than files 🙂
Ahhh, no, I'm a serious convert to Roon. Best thing since sliced bread and all that....
I just hope that you migrated to ground part of roofing job
Yes ZM, I am hoping to never put myself in a position where I am uncomfortable again. I actually wish to spend my hours cooking on a hot rock slab over an open fire like my friend Alexandar (sp?). You must show me the light one day. Perhaps a face to face meeting is in order.
If I live that long, that is 😉
I'm 53 and just recently realized that I'm no longer 16.5
Of course you are! You are the Omnipotent, transcendental, never aging slim-line Zen!
I had better
@ Cal!
And I thought that I had troubles!!
Same thing... alter the pH joint fluid balance and the Allopurinol is no good ...and the resultant gout attack is a real screamer!Some of the rest is just bad luck.
Just get well again and become Zen2!
Ouch. I hope you're on the mend soon.
(And yes, the ESB is still burning dirt. Although they're promising to phase it out....)
The middle of Ireland must be about 19m below sea level by now!
Thanks for good wishes
Jeez, I go to work, come back and all hell has broken loose!
Okay, here's my life over the past 2 1/2 weeks. While babysitting my grandson for 4 days, as I went into the garage my foot rolled off of the short bottom step. Then, as they say, things went into slow motion as I headed to the concrete grabbing at whatever I could to break the fall and then bonking my head. Like you Cal, I stayed down for a while, assessing the situation. Luckily nothing broke, however I was pretty uncomfortable for about a week. Then your flu migrated to Napa Valley and my wife and I caught it! Going on day 8, we are finally seeing improvement!
I to have come out of the closet.
PS. Can anyone coff up a decent shelf industrial analog line level coax for single ended use, something usually sold on roll or per length?
An English garden Zen Gnome...his price label is in Sterling!!🙂 😛
But as he really looks more like an older version of Cal it should be in Canadian $s! 😉
Hope that the Rum did the trick for him!
use cheapest Mogami
Heared about it but never figured out where to buy. Big industrial providers like Mouser, Distrelec etc usually offer Amphenol, Belden, Alpha Wire, TE etc.
Belden 8240 seems decent although its solid copper, PE insulation, maybe messy to solder to rca.
in that case , go to local grocery store , buy few apples , bananas and first decent looking antenna cable
Mmm. Maybe this one.
https://www.elfa.se/Web/Downloads/_t/ds/RG58 CU_eng_tds.pdf?pid=30070491
Antenna cables have those steel shieldings, me not like to solder that.
yup
or , if you have some old stash of coax network cables , it'll do
It was a while since we left Token Ring to Ethernet, but not even I know whats at the bottom of the boxes.
- The Pass Pub: The High-End Off Topic Thread
