forgot , buzz if you need xover schm
you got original one ?
Yes please, nope just snatched them on the fly with phone. Home in a bit
one of these
though , I tend to prefer System 15 , at least for HF part
...... Evolved on blog?
go , read : tannoy | Search Results | Zen Mod Blog
I believe yours are pretty much as 3833(3836) , except spyder compliance (stiffer , for higher Fs and smaller Vas)
well , except ......
. Btw didnt find OB build thread, only WAF.
Edit: Now found "older posts-buton", looking at OB-filter semi finished. Evolved?
Thanks a bunch Massa. Btw didnt find OB build thread, only WAF. Shall I not go for wider baffle ideally? Those for series bass helper chokys?
ya sillybikelovingsuede
of course ya can use wider baffle
obviously you didn't read , just looked at porn ..... I wrote dims of me baffles are determined by space available , then accomodation resulting in sort of H frame (or hybrid between U and H ) function
I hope you didn't in same situation , having space for at least 70cm wide baffles
Some other sweeties I stumbled over
ook ya , me hate
yes and no , irrelevant
what's relevant for ya is - find proper choke in range of 6-9mH and put in series with bass helper , irrelevant what type of enclosure for it you're going to use
Torobar is having good ones , 8.2mH , tried and blessed in my Sonido speakers construction
very good price/value ratio
Ordered torobars thx. If I have room, yea I make room. So do you recommend me to dig for comps like that OB-filter?
... So do you recommend me to dig for comps like that OB-filter?
Que?
well , https://youtu.be/A4I9DMSvJxg ....
of entire xover , made for my Absolute WAF Tann OB , you can use just bass helper part
as you can see - my Tanns are Pepperpot ones , while yours are Tulip equipped ones , so HF part of xover is mucho different
yes , go for System 15 xover as start , later you can fine tune what's needed - most probably just value of series attenuation of squawker and , depending what solution you choose for bass helper , maybe some series resistance for bass helper driver
if nothing else , when you have some time , measure at least Fs of Tann drivers ..... just to have that on file
edit : and yes , porn is mandatory
Your letting you musical taste show. I was driving with one of my daughters at about the age of five years when war pigs played on the radio. To my surprise at the siren call at the start the kid exclaims "yes...War Pigs...make it rock and roll...". Make it rock and roll means make it loud enough to **** off Mom.
https://m.youtube.com/?#/watch?v=K3b6SGoN6dA
you need progz (I mentioned) or you already have what's needed ?
disclaimer - you need (any) 32b Win for that
- The Pass Pub: The High-End Off Topic Thread
