Talking of 'talians has anyone heard anything of the famous Wed WolWo who used to frequent these pages?
Where did you find such small lighters?
I bought a pair of the 'wind tunnel' heatsinks many years ago and drilled them out with the UMS mosfet spacing but it will take considerable metal work to make it into an amp ...
Maybe T-bed2 for me as well? If you can't be original, why not copy from the original Wakoo (ZM of course)?
today I did some additional drilling on T-Bed 2 htsnk - made all needed holes for Babelfish XA252 mos pucks bolting, same as for strategic placement of Tokin elevator thingies
fun times ...... 🙂
fun times ...... 🙂
Pics!!
How are we supposed to make sense of «pucks» and «elevator thingies» without pics! Not all are equipped with the foresight and enlightenment of Zardoz. I feel more like string Emil.
(Greedy Andy trying to get a glimpse of Chokys Babel 252).
Yes, good points, thank you. I’ll save it for a cool AB amp or class D. Maybe for my first EF3 build...
I have used the case for a PC; it is beautiful and it works. In order to cool my graphics card, if have bought a couple of CPU-cooling extensions, which work very well for everything else in a PC which needs cooling.
Stopped using this PC a while ago. The only problem was, that the RAM was not cool enough, because I have not really found a way to connect it to one of the four big panels.
Each of the four sides can dissipate between 65 and 80 Watts of heat.
There are some photos on tonymacx86
An idea for hardware for this 3d printed hackintosh next cube? | tonymacx86.com
I believe I have earned one of the un-coveted stupidity units today through improper use of a variac. Thankfully unceremoniously. Did you know that ZM can type in bold, red, and all caps at the same time? It was quite impressive. May have earned a high multiplier on that one. Quite easily KZM or MZM.
I invented Papaland's Stupidity Unit today
of course, Label is ZM for everyday use, feel free to use same prefixes as for Farrad
no way, Jose
two news:good one - you're alive to hear my yelling
bad one - even with that, you're at measly 100nZM
Do you think that starting a "What DAC do you use" thread would be relevant enough for the pass labs topic? I am trying to figure what all of us NP fans like. Thanks!
How I know I'm developing a "problem". Wife suggested I see if I can acquire any remaining assets of Radio Shack.
- The Pass Pub: The High-End Off Topic Thread
