Check here... Not only the othorn
But the skram...the skhorn...the ckram...
The gallahorn...
That's the website where Josh Ricci share his plans
https://data-bass.ipbhost.com/forum/10-bass-projects/
Also some high performance top cabinets
By Peter Morris
Check PM90....PM60.... And PMA60
https://soundforums.net/community/forums/diy-audio.28/
The gallahorn...
By Peter Morris
hi Josh - thank you for sharing the plans with us. would you kindly send me the SLDDRW and PDF prints to my email ( rian.adamian@gmail.com ) when / if you have the chance? thanks, i hope you're doing well.If anyone wants the plans for this cab I have a cnc type Autocad print made up as well as a SLDDRW print and a PDF print of the cabinet plans. It should be enough to build it or adapt it for your own needs if anyone has a need of a cabinet like this. You will have to pm me your email address as the prints are too big to attach here.
Additionally there are other drivers that should also work very well in this cab.
TC Sounds Pro5100
18Sound 21NLW9600
18Sound 18NLW9600
18Sound 18W1000
B&C 18NW100
B&C 18SW115
B&C 21SW150
B&C 21sw152-8 (8 ohm version looks ok, but not as good as the 4 ohm.)
Beyma 18SW1600ND
Faital 18XL1500
Faital 18XL1600 (This one doesn't look as good as the 1500 but it could be a new model.)
Fi Car Audio BTL N2 18d2 ( It does not look as smooth as some of the others and it is a little less sensitive, but excursion would never be an issue with its 30mm xmax and 40mm xmech. Might be worth trying if someone is crazy enough.)
When the subs are complete I will do a full outdoor ground plane test session on them. That will be a few months from now though.
Heyy maxolini, at the moment I run othorns with b&c 21sw152-4, martin audio 215mk3 and PM90Hey phanthom will you share your setup details
https://www.instagram.com/kantarion.sound/
- Subwoofers
- The Othorn tapped horn
