Might be smart!
This is my solder station: AOYUE 936 Anti-static Soldering Station soldering tool | eBay
Aoyue 936 Solder Station Variable Temperature Control | eBay this is the same? Buying from America wont happen, shipping costs way too much. But ebay.co.uk is OK and also amazon.co.uk
I have the same model, the 936 is quite alright but it is really essential to keep the tip clean and freshly tinned, as with every iron I suppose. There is temperature control, albeit via an analog dial, and I can hardly tell whether that is all too accurate. Over time I got used to various settings depending on the task at hand.
There is a newer model with digital temperature control. Those have a reputation of tighter regulation, i.e. once you touch a large mass of copper with the tip it will quickly react, whereas the analog counterparts have a much larger temperature drop before they turn the heat back on. One is easily tempted to dial in a higher temperature, which is not always too healthy for the more sensitive parts involved. For casual use and ordinary PCB work though, the 936 is really good value and leaves not much to be desired.
Kind regards,
Chris
Kind regards,
Chris
Could someone help take a look in here? i have some issues with my o2
http://www.diyaudio.com/forums/headphone-systems/218490-my-objective-2-having-weird-issues.html
Thanks, I follow you reasoning. Best wishes and do share if all works out well.
Thanks! First step would be to gather component footprints and exact board dimensions of the existing O2 project if RocketScientist or anyone else has them and start to modify and add new footprints for an SMT version. After that, I can simply re-create the schematic and annotate it into a PCB project using Altium's software.
Oh, a silly question.
I have removed the gain resistors for a 1x gain, but is there any way to get even less gain?
For low level evening listening I still find myself having the volume control all way to the bottom almost which means I get a little channel imbalances.
I have removed the gain resistors for a 1x gain, but is there any way to get even less gain?.
Here: http://www.diyaudio.com/forums/head...-crc-diode-cap-heatsink-mods.html#post2794079 🙂
I've started a crowdfunding project for some nice SS front panels if anyone is interested.
Objective2 Headphone Amplifier Stainless Steel Front Panel -- Indiegogo
I love the idea!
I bought one, and hope that more of you do the same to make this great idea a reality!
Come on, everyone, support the community!!
What case is it for?
I looks like it's for the Box Enclosures item that is the 'stock' enclosure.
Yup what he said - I will edit the listing details to clarify this fact - thanks for bringing that up.
Also if anyone is wondering why I posted this on Indiegogo -> I tried posting it up on Kickstarter first but was rejected with no explanation.
Hey guys
I'm onto my second O2 and have got a few problems, ran the tests as per the instructions from RocketScientist.
Ok, all is well and fine until I check the Dc voltage at the output ( P2 ) and am getting 11.3v on each channel????
Any thoughts whould be welcomed
Cheers
Cheers
Hey guys
Cheers
Solder bridge? That would be my first thought, never had one with that much DC voltage on the outputs, even with a bust MOSFET...
Stefan
Had a good look with a jewelers eye piece, no bridges?
Also, its on both left and right channels?
Maybe the fets?
Maybe the fets?
Hey guys
Cheers
I got the same problem with 11.3v DC on P2 and i replace the Q2 and it fix the problem.
Thanks for the parts swalter.
Good news.......Fet tested fine, have ordered a couple just in case
Bad news!!!...Just ruined at least one trace on the PCB getting it out and back in!!!
Does anyone have a spare PCB they would be willing to sell and post to NZ ??
Cheers
Cheers
- Headphone Systems
- The Objective2 (O2) Headphone Amp DIY Project
