The Kjeldsen OB build thread
Thought it was easy to work with this flixibel wood. But it have a life of its own. Had to invent some temporary sticks to hold back the pressure and keep the more or less circular form
Joined 2008
What is the lowest step (in ms) you are able to achieve? I can adjust mine in 0.023 ms steps - which is around 8 mm if I am correct. The trick is to use keyboard arrows up/down or left/right instead of a mouse.
Mine do not remember the settings if I load them from a saved preset after power off. It remembers only the settings in the default preset - maybe you know a trick for that?
