2) Below app 17Hz the noise is defined by Q1 and R8. Further it get accentuated by the resonance mentioned earlier. You can't hear this, but if you but finger on the woofer, you most likely will feel it if the volume is set at "realistic" level - whatever that is.
Below 17Hz the cartridge itself is flapping around all over the place anyway!
Ok not a $1k but...
Four of these... at 1.3"x2.3" (33mmx59mm) That is a lot of real estate. The 1uf is only .66"x1.3" (16.8mmx33mm). It's already off board....
If you have to go to 10uf then maybe another thought needs to come about, like jfets to shrink the caps.
Hi fellow RIAAlists
AC Performance:
I general it performs quite well with except maybe above 10kHz, where the output rises. Otherwise very nice.
Try adding a capacitor with a value between 4.7nF – 10nF across the 2K7 resistor in the feedback.
Your'e absolutely right, I've only changed what I felt neccessary .
I guess the 2k7 resistor where put in in order to increase the gain. Maybe you could remove it all together. Apart from lowering the gain, the distortion should go down a bit as well. Only issue could be stability.
Interesting work. BTW You can realistically simulate the 2N2540 current source by an ideal current source with some parallel resistance of a few Megohm.
When you mention a cap of value 2m2 are you really meaning 2200uF or should that actually be 2u2?
Jan
Jan
I do mean 2200uF (in stead of the original 1000uF)
Lars
Ahh, clear. Some people wrongly use m for micro instead of for milli so not always clear.
Jan
Has anyone done the suggested MrkII mods and tested/measured the results? I'm giving serious thought to getting my boards and parts out of the basement and getting this up and running in my system. Not that I don't trust simulations, but ...
Hi all,
I have one 'red' board I bought from Hannes some time back (see post in this thread) I have not used for various reasons (had a health issue back when I bought the board and one thing led to another...). I am selling it in the Swap Meet. I hope putting this here is OK mods; I'm only trying to contact the people who'd be most interested and am only selling the board for the original price of AU$18 postage free (equiv. of 11 Euro, but that includes postage anywhere).
Cheers
Stuey
Cheers
Stuey
Stuey,
Sorry to hear about the health issues and hope you are doing better now. Sometimes projects get delayed/cancelled... I also have a board and most of the parts, but haven't been able to make progress.
Hope you can sell your PCB quickly and someone else of the DIY community gets the opportunity to build and enjoy this phono preamp. Good luck!
Nevermind, I see everyone else just bypassed.
Finally... sounds good so far but burn in I am sure has a long way to go.
I get a little noise on quiet passages, need to figure that out... no enclosure doesn’t help.
I tired no C9, it needs it. I have R6 bypassed by 22uf lytic (probably under 22uf measured)
KSC transistors, I have BC’s to try later.
Caps are 940C, my fav I think. Lytics Silmic II, also a fav.
I didn’t go for 10uf films, as you can see 1uf already requires a work around.
Voltage is 41~ but stable. My transformer is only 34v... nothing else avaliable that fits my transofrmer board besides a 40v. I omitted the CMC because I have one in the power conditioner. The DCS1 rectifer board has a transformer snubs with a bypass, KG caps.
I loaded it with all but the 25pf cap because my cart says 400pf.
I don't know what's up with the links on those thumbnails...
https://i.ibb.co/ypHVd2K/F961524-F-7-C8-B-40-CC-A73-F-6-CD701-F7-DECC.jpg
https://i.ibb.co/zfNHwfH/D1-EFF1-EE-0-C61-4-C70-8317-3-F41250665-AD.jpg
https://i.ibb.co/JRH09QJ/23358-D6-E-0903-4-AE2-9-B1-E-9-F26-C4789-AED.jpg
Sadly I can't listen to it. It sounds amazing but without an enclosure (I guess?) It's a complete an antenna for 60hz and the buzz from the turntable above it. If I turn the TT off (just the platter motor stuff) a hash of buzz goes away but 60hz will not.
Sigh... back to my ghetto POS preamp.
If it’s under your TT. Find a thin sheet of copper and place your TT on top of the copper and that my block the buzz your getting. You can get some at HP or true value hardware
Well I’ve tried moving the TT and nothing. But I did find my TT ground from TT tonearm to TT motor chassis was broken from, well, I dunno.
I replaced it to no avail. But I briefly tried safety ground and it worked well if I touched just the right spot on the platter and chassis...
Touching film caps insulation to signal ground cuts noise down really low.
It seems a chassis is required. But I would need a monster chassis to get this obtuse thing in. Anyone interested in a board that can fit all the parts without too much trouble? As in they can lay down? Few resistors properly fit because you have to settle for 1/4w often, since stock on RN’s is a mix between 1/8w and 1/4w.
Moved to steel box. I have the TT ground connected to a phono that goes straight to CP1. Still have buzz 🙁
My transformer isn’t oriented to project fields into the high octane. Ugh.
- Analogue Source
- The high octane phono preamp
