The diyAudio Firstwatt F6
yup, that's the part I like too....drilling / tapping, thinking about construction, WAF 😀
In one big mess creating something beautiful 🙂
Oh, its not that bad, but with the First Watt and Burning Amp stuff all on that same layout, and same power supply operating most all, modular design and so forth, it would make converting an F-5 to say a F-6 easy peasy, plus the outputs not removed would mean no early replacement of Keratherms and so forth.
Just un-do the power supply and signal wires, remove heatsink with boards intact, replace with different heatsink/amp, brackets and all, in very short period. So far, I have built everything separate in its own case.🙂
Russellc
You seem to be doing well with only two. They must be big...
By the way, since we are clowning around, have you thought about
Zen Mod's Amp Builder's Summer Camp
? That could bring you some extra cash to afford new toys.
And before anybody complains about off-topic posts, I am waiting for my PCBs, trafos and case...
I did my part, it ain't my fault that it's taking so long.
before saying anything , take care of using that >😎< smiley ....... we all know which Dark Force is solo entitled to using it :devily:
regarding Zen Mod's Amp Builder's Summer Camp ........ there are some things pro et contra ;
pro: I'm always for fun , also more liking to dream about and to make them , then to actually have them ; it probably helps that I already have too much amps (etc.) but after some evaluation , I'm always keen to proceed with dream about and .......
contra: it would be somewhat expensive for participants , at least from your side of Big Splash (considering that you titled it in English and there is obvious analogy to Papa's Camp) to make a hop to Serbia ........ :rofl: ...... and even not considering that I'm not so knowledgeable in making amps ....
Although much has been changed for rhetorical purposes, it must be regarded in its
essence as fact. However, it should in no way be associated with that great body of factual information relating to orthodox Zen
Buddhist practice. It’s not very factual on motorcycles, either.
Right off, the 18 ohm RN60s are a no-go from Mouser unless you want to wait several months for them to come back in stock.
At the time that I bought mine (about two or so weeks ago) they didn't have 18 ohms in RN60, but they had 18.2 ohm, which is what I went with.
Just as a general FYI (if it hasn't been addressed elsewhere and I missed it); I used 50v 1000uF Nichicon Muse KZ's which are seemingly massive at 18mm x 40mm. On one of the PCB's one of the caps is nearly pressed up against a 3 watt resistor. I don't think it'll be an issue, my 3 watters are raised off the PCB so I could bend it away from the cap. Just a warning if anyone else decides to use monster caps!
:cheers:
