The constant voltage in the network - myths and reality - 0
How is that forum better than this or any other? There are also amateurs.
Here are the company's date:
The large-sized toroidal transformer of the large power capacity of about 1.5 kVA is adopted as a power transformer. Furthermore, it excels in heat conduction, and using the high load material of the vibrationproofing effect, it adheres to the unresonated aluminum case of efficient heat dissipation structure, and the influence on the exterior is intercepted.
Impedance of a toroidal transformer is very low in order to coil thick copper wire around a doughnut-like core, and it is small, and conversion efficiency is very high. In particular, in P-1000, the super ring type is adopted, the section of an iron core can also roll a coil in a circle closely circularly, and since adhesion nature is good, a loss can lessen the leakage flux at the time of load, and a roar few,Furthermore, iron loss and in rushes current are small made by making the cross-sectional area of an iron core small, and enlarging the rate of a bulk density of copper wire.
Accuphase/kensonic P-1000
