The BULLET Amplifier 10 Watt Class A and Current FB
Test board is ready, it's good enough for testing the design, and by request it's not crowded.
I'm sure there will be more modifications on the schematic, so final one will be of better layout and standardised to some common heatsink/case. Will be rechecking schematic and pcb tomorrow before posting gerber, i'm tired like a dog atm, don't want a mistake to creep on.
Now we wait for Gerber files.
You are so nice to make this for me :)
This is the new power supply.
Should at least provide 9 Watt Class A.
The bias should be 930mA at the 17.20V output.
Reactions: 1 user
@lineup ; Yes, your simulation data is correct. but the data is not pure classA.
For pure classA, I expect the bias current to be the same as the peak currents. As you increase the bias current, distortion increases. This problem disappears when you increase the supply voltage.
The bias current is 0.9A.
For push-pull this means 1.8A output peak.
1.8A x 8 Ohm = 14.4Vpeak
This is well more than 12.65Vp which is the 10 Watt level.
With 33.5V 10W still is a bit over, I think. With 35V, I get 10W with only 0.0026% THD. In the waveform of the Id's it can be seen that it is not clean anymore, but not to the degree of causing much distortion, it seems.
VCC 35V, input 1.2V. Current in lower FET.
I begin to wonder if you two have the same SPICE MODEL for the ECX10N20 and ECX10P20.
So here are the models I use:
  • ECX10N20 ECX10P20 Spice.txt
n
You need source resistors for power transistors and some kind of thermal feedback to stabilize the quiescent current thru power transistors, at least if you want a stable and reliable system over time.
No you do not need source resistors at all for lateral mosfets, only if you want to put some in parallel. Nor is thermal feedback necessary.
Reactions: 1 user
I've rechecked schematic, and pcb, no drc errors, so here's gerber. As usual this is test pcb, it may not work (small chance (many spice tests here) but i gotta say it). Dimensions are 100x80mm, 2$ on jlcpcb so cheap for test. If it passes without oscillations, or any other issue, and additional new modifications, there will be v1 release. Enjoy.
  • Gerber_PCB_bullet class a amp.zip
Reactions: 5 users
Regarding the SPICE models, I suspect that there are two different models. The first is probably based on the old Hitachi 2SJ50/2SK135 where there was a significant Rds resulting in a loss of available voltage swing across the mosfet, hence less power output. The second is probably a revised model where there is less Rds to reflect the current Exicon mosfet hence more power is produced. I believe Exicon have been refining their production of the lateral mosfets over time. In my experience given the same voltage and current conditions, the Exicon mosfets produce slightly more power that the older Hitachi mosfets. I also suspect that someone decide they were identical thus copied the Hitachi model and relabelled it Exicon.
@ Brijac, a few comments on your gerber file as shown in post #72.
The 8 ohm resistor you show at the output is not required - that is actually the speaker coil.
Also, you show component values on the silk screen, but should also show the component number - eg R1, C1 etc to avoid confusion.
Just my 2c worth.
No, I do not. Mine was included in above LTSpice file. They are different.
Will try what happens when using yours.
EDIT: LTSpice crashes when I try to use yours.
The question is what models are the most correct.
I have compared my models with the datasheet for ECX10N20 and ECX10P20.
What I can see my models are a bit optimistic.
I think the truth is somewhere between my models and yours.
mkk76
The 2N5551's collector output should be connected to KSA1381's base. As per your scheme, you have drawn the KSA1381 base connected to the DC offset resistor string. as a result the amp will not work. Similarly your PCB has the same mistake.
Here is a picture of PCB.
There is no need for heatsinks on the KSC3503 and KSA1381
Can we spot more errors?
