The Boominator - another stab at the ultimate party machine
Cross overs done. Now I need to round over the baffles, do a test glue up and driver fit, and decide if i need to drill dowel holes for the baffle to aid in alignment.
Alignment dowels for the port are perfect. Larger picture
Center brace routing is done.
A battery fits perfectly:
Also, I've been trying to keep busy while aterren works his magic.
I designed some stainless steel panels and got them laser cut, and I'm super happy with how they turned out. Here they are, assembled and ready to go.
Hey, you've been holding out on us Micahbf. Nice blog. Where did you run across Anderson connectors? Are you into R/C?
Thanks! Guess I was just shy about the blog 🙂 I think I originally came across the Powerpoles just googling around for good low power DC connectors. I've been really happy with them so far! No experience with R/C, though.
As for the fuse on the battery, yeahhh, realized that not too long after installing it. Oh well, double safe!
Random tip. An easy way to secure the battery is to mark it up and then outline that with a couple of large headed phillips round pan type screws. It only needs to be on one of the compartment walls as the battery is so snuggly fit that it doesn't need more than that to hold it.
And the MaxAmp is also already fused. So that would make your system triple fused 😀
Getting close...
Progress Update:
Ready to glue up ports. All glue surfaces have been scuffed with 80 grit sandpaper and wiped clean with a damp cloth. The damp cloth leaves a bit of water behind to aid in the glue drying.
Clamping the port. In the second picture you will see I used way to much glue.
Once dry, the dowels need to be trimmed and excess glue needs to be removed where the center brace meets the port and on the inside of the port.
Another view of parts sanded and wiped down:
Next is a glue up dry run. Tip: Always do a dry run. This will help ensure you have enough clamps and help you with the assembly order. For example, I found the assembly was easiest if I put port end plate in, the the divider, then the middle divider. Without the dry run I would have had to discover that while handling parts with wet glue
This sticker on one basement window when we bought the house. I put my glue up table under this window. I figure that ensures all glue up results are 'just ducky'. I don't know what I would have done if it had been a Goofy sticker.
Drying:
And the result:
I think you should also consider aluminium, because when it is anodized, it is far more scratch resistant than stainless steel, in fact stainless steel is probably one of the worst product names in the history of products because it does stain quite readily.
The negative is that you have to anodize it yourself, but it is not that difficult and you can give it funky colours.
Progress Update:
Ah look it will work but Gorilla glue isn't the most ideal glue here, as Gmarsh said above, Loctite PL premium is far superior, it's also a polyurethane glue, but it doesn't expand as much, and it is much stronger.
