The Black Hole......
I wasn't sure if the 24/96 gets through without being downsampled, I guess it does.
It should do. But often hard to check.. There are often some points of concern, esp if a windows machine is in the way. In your case with Chromecast double jeapardy! I just fitted some new Comply tips to my headphones to listen at work to the samples and realised I can't confirm bit exact without ASIO4All and having tried that before it stops other things I need working. Phooey.
Where does 40KHz come from? That which JC and I and others have used as a min for decades ---->from listening tests....the linear phase deviation has to be less than 5 degrees. from 20 to 20KHz which means the freq response must be from no less than just under 1Hz to 35 KHz. (6db/oct). So we just say 40Khz, -3dB.
THx-RNMarsh
Ref Handbook for Sound Engineers.
THx-RNMarsh
Why do you feel this should be important. Your speakers have orders of magnitude more phase shift.
Edit: where in the Handbook did you find this? Will look it up.
I think it is a good idea to have an amp trading slightly higher distortion for reduced speaker distortion like your 0.22r in series with the speaker trick. Why did you categorize my question as crazy?
It is the detectable change... delta ... which does not matter if freq response is flat or distortion is not zero. To a degree.
yes, a slight reduction of high OL neg fb voltage amp will barely be noticed compared to a 50% drop or more in speaker distortion.
-Richard
THx-RNMarsh
Handbook for Analog Sound Engineers. Nowadays, we can do filters that start at 22kHz and has almost 0 phase deviation at that frequency.
But, obviously, the analog will output *something at 34Khz whereas the digital will be more or less silent at that frequency.
Well, from what i have measured, there is considerable HF after the filter still. Needs more effort .
THx-RNMarsh
