I think you are conflating things that are not related Bob.
we're talking about the (if) audible effects of brick wall filtering that occurs with a 44.1k sample rate.....no?
I'm just looking at the obvious problems the lower the sample rate is....they still exist at 44.1 even though we're not supposed to hear them.....right?
^ Given where you are now, George,
A CT scan report talks about some “obvious signs of gray matter degeneration” whatever that may mean (soldering iron gun without electronic temp control, 60/40 solder, NE5534?) 😀
George
…Shannon...
One thing i remember from my university days is that what you are sampling needs to have NO signal above 1/2 the Nyquist.
That rule is broken all the time. Hence, i expect, why it is being explored.
dave
Well kinda.....some in the recording industry consider up to 48k sampling ‘lossy’
Most all digital recording is done at 192.
This is just what I’m coming across when I research this.....don’t know if it’s gospel or not.
That's not the case Bob. Most recording is done at 48k / 24 bit, then 96k
and less again use 192k.
TCD
JC.... how do you like those heat sinks and power transformer !!
-Richard
Richard, WRT your power amp, did you get to the bottom of that oscillation
problem? Was it in fact an oscillation issue?
TCD
Yes looks as though I may have been misled in a couple articles I read about 192 recording,
Some Dvd uses 96 or 192 .
many recording studios look like they’re going 24/96 with 192 used in some.
So yah Terry.....not yet!
Sorry......shouldn’t post while I’m working, fact check goes to the wayside! 😛
People using/developing time-frequency analysis methods are using "temporal smear" or "frequency smear" or even "spectral smearing" quite ..er...frequently. I'd guess it is not just for marketing BS reasons...... 😉
A honest question from is.. please defined these properly - I'd like to know!
dave
Yes - this happens at the recording (A/D) and can not be cured later - it will always be there, impregnated in that recording forever.
I know sad isn't it? What informs the polka dots on the speakers?
dumb question. For a modern SD ADC, what IS the fs/2 ?
Clueless in Gaza?
George
George,
I do remember you mentioning your mother's (grandmother?) problems. Normally my understanding is they are not hereditary! I get that from a cousin who is a specialist in such issues. His mother had very serious problems.
I also recall you have cut back on alcohol consumption, another factor.
So perhaps your medical care is doing good for you. But just in case be kind to the wife and nearby children. (Seems to be in your character as shown here.)
My best to you.
TCD
No oscillation problem at all. That was some one else bright assumption. It was a non-tracking bias situation.
THx-Richard
So, what is it you are saying, what FS is used by most digital recording? Kindly enlighten us.Where did you picked up this rubbish? Let me guess - Google university.
Other examples:
I dont know why anyone, at this point in time, is still defending CD 16/44 as plenty accurate. It is pretty much indefensible to people who listen. All have moved on and for the better. Sound has greatly improved because of it. Thank the Gods.
How can we make a dynamic loudspeaker a more accurate reproducer? Lower its gross amounts of distortion?
THx-RNMarsh
- Member Areas
- The Lounge
- The Black Hole......
